Seagate ST3320620AS very slow copy
Posted: 17.03.09, 07:31
by slack
I have one Seagate hdd which is working very slow , after every copied LBA it gives this lines
CE Log ErrCode=43 LBA=2501220c Type=4 Remove from Pending 2501220c
AT Er 00 Nwt Er 43 RdWr 1f23d.00.0005
ATA St d0 Er 00 Op 22 e, 159b3ff5,0163 0163 0000
Niwot: 9ff79ff7 b8 9ff79ff7.3.acd 0000 005f 0000 1000
DiskAccess ReadSector EC=43 at 01f23d.00.0005
It copy 1 LBA in 5 seconds, if I try to copy with Read Ignore CRC it copy ~100 LBA in 2,3 second but is still very slow transfer rate.
If i do one Logical Scan it is working normally but when I try to copy..... begin to click and give that log in termminal.
What can be the problem ?
Thanks.
Re: Seagate ST3320620AS very slow copy
Posted: 17.03.09, 09:06
by Igor
Dear ionut_bit,
It's a head problem. Head Swap will help.
So the donor drive must have the same Config, Site Code, Capacity and compartible heads map.
Regards.
Posted: 27.03.09, 11:11
by steven
you can make sure by checking head in terminal
will tell you which head was dead....
Posted: 28.03.09, 05:44
by Alberto
Its adding sectors to the pending list, maybe could be stopped or bypased to read sectors, thats possible with UDMA no?
Posted: 30.03.09, 10:13
Lots of error type 43 usually means dead head or heads in my experience. Also, head test I do not think is totally accurate. I would replace heads and write the results here.
Posted: 30.03.09, 11:39
by steven
OK... Please tell the whole progress.....
