ST3250310AS 3.AAF 7200.10 NHPLUS2HD cannot create loader
Posted: 23.10.08, 15:40
by aviko
When i try to create loader it stops on detecting ata overlay position:
Code: Select all
Selected family......................... : Barracuda 7200.10 Galaxy2D
Selected model.......................... : ST3250620AS
Model by ID............................. : ST3250310AS
Current utility options are outdated!
Loading default settings!
Then press OK!
Detection of HDD COM port baud rate..... : 9600
COM transfer baud rate set to 921000
Test  : Saving LDR from HDD
HDD profile file......... : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Barracuda 7200.10 Galaxy2D\ST3250310AS-3.AAF-6RY7H7KM\Data\LDR\SgLDR.ldr
Will be stored........... : ROM, App, CERT code, CERT tables, Ovl 0, Ovl 1, Stuff, DRV cfg
DRV cfg reading...
DRV cfg reading......................... : Ok
STUFF reading...
Detecting Stuff position...
Terminal : detecting SA bounds...
SA bounds identified
Stuff cylinder.......................... : 0x16DF8
Vendor Data start....................... : 0x14
PN...................................... : 100505855
STUFF reading........................... : Ok
CERT code reading...
Trying to load CERT
CERT Rev................................ : .03U
CERT code cyl. index.................... : 0x32
CERT code length........................ : 0x520
Block 0, 0x16DF0 : 0x0 : 0x0 (0x35C)
Detecting next track.................... : Ok
Block 1, 0x16DF0 : 0x1 : 0x0 (0x1C4)
CERT code reading....................... : Ok
CERT tables reading...
Detecting CERT tables position...
Detecting CERT tables position.......... : 0x16DF2 : 0x0 : 0x1C4 (0x14)
CERT tables reading..................... : Ok
Detecting ATA Overlay position...
and it stops here. RxD led on terminal blinks from time to time but nothing happens.
I need loader to app "pending" bug but if i create loader without ata overlay 0 and 1 it doesnt work in DE. maybe i just need to correct some parameters in utility
Code: Select all
2>/
T>y
Command Inactive - No VALID Cert Code Detected
T>VALID Cert Disk Code Detected - Revision # .03U
T>y
                  PhysCyl   GrayCyl
 1st Sys Cyl      00016D8C  000180C6
 1st 0 Offset Cyl 00016D96  000180D0
 1st App Code Cyl 00016DA2  000180DC
 2nd App Code Cyl 00016DA4  000180DE
 2nd 0 Offset Cyl 00016DB0  000180EA
 3rd App Code Cyl 00016DBC  000180F6
 4th App Code Cyl 00016DBE  000180F8
 1st Adaptive Cyl 00016DC0  000180FA
 1st UsrDfect Cyl 00016DC6  00018100
 1st Alt Pool Cyl 00016DD2  0001810C
 1st CertCode Cyl 00016DF0  0001812A
 1st IntfCode Cyl 00016DF4  0001812E
 1st Intf Sys Cyl 00016DF8  00018132
 1st Cert Log Cyl 00016E32  0001816C
 1st Decay    Cyl 00016EB2  000181EC
 1st SPLASH   Cyl 00016ECC  00018206
 Last System  Cyl 00016ECD  00018207
Copy    PhysCyl      StartSec length    Name
0000    0016D96    0000    0002     BA
0001    0016D96    011E    0002     BA
0002    0016D96    023C    0002     BA
0003    0016DB0    0000    0002     BA
0004    0016DB0    011E    0002     BA
0005    0016DB0    023C    0002     BA
0000    0016D96    0002    0003     RDL
0001    0016D96    0120    0003     RDL
0002    0016D96    023E    0003     RDL
0003    0016DB0    0002    0003     RDL
0004    0016DB0    0120    0003     RDL
0005    0016DB0    023E    0003     RDL
0000    0016DA2    0000    0238     AC
0001    0016DA4    001E    0238     AC
0002    0016DBC    0000    0238     AC
0003    0016DBE    001E    0238     AC
0000    0016DC0    0000    001C     DriveAdaps
0001    0016DC2    0035    001C     DriveAdaps
0002    0016DC4    006B    001C     DriveAdaps
0000    0016DC0    001C    000A     MediaZonTbl
0001    0016DC2    0051    000A     MediaZonTbl
0002    0016DC4    0087    000A     MediaZonTbl
0000    0016DC0    0026    0004     ACFCTbl
0001    0016DC2    005B    0004     ACFCTbl
0002    0016DC4    0091    0004     ACFCTbl
0000    0016DC0    002A    0004     BackUpACFCTbl
0001    0016DC2    005F    0004     BackUpACFCTbl
0002    0016DC4    0095    0004     BackUpACFCTbl
0000    0016DC0    002E    0018     AltLst
0001    0016DC2    0063    0018     AltLst
0002    0016DC4    0099    0018     AltLst
0000    0016DC0    0046    00AA     DosTbl
0001    0016DC2    007B    00AA     DosTbl
0002    0016DC4    00B1    00AA     DosTbl
0000    0016DC6    0000    02E9     UsrSlipKBALst
0001    0016DC8    0000    02E9     UsrSlipKBALst
0002    0016DCA    0000    02E9     UsrSlipKBALst
0000    0016DCC    0000    02E9     UsrSlipDftLst
0001    0016DCE    0000    02E9     UsrSlipDftLst
0002    0016DD0    0000    02E9     UsrSlipDftLst
T>
Re: ST3250310AS 3.AAF 7200.10 NHPLUS2HD cannot create loader
Posted: 21.11.08, 20:13
by aviko
ok, i got answer from ace support. this model is still not supported by pc3kudma, thats why created loader cannot work with de and apply patch for "pending" bug.
