7200.7 unable to read system sectors code (error 71)
Posted: 29.02.08, 13:31
by JiS
Hello, i would like to ask you if there is any way to recover the data from Seagate 7200.7 drive if the drive cannot read the system sectors code (error 71). Is it possible to transfer these data to RAM somehow from different drive? Or some kind of hotswap? Or to try to write the system sectors from different drive?
Interface task reset
4096k x 16 buffer detected
APLUS - 1_Disk S.07 08-16-04 10:34
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
3.01 08-16-04 10:35
(P)SATA Reset
Not Interface Age!
VALID Cert Disk Code Detected - Revision # .046
Cert Table loaded
T>Age=60 Type=E0 MxCyl=17C5C MxHd=0 MxSct=370 BSz=2000 TCode=0000
T>YE3
Code - 71 Track 0F332.0.1BA Sns 1BA Rty F7FF.FF.80FF Rtf 1862 LBA 00000000
T>/7
7>r
$Switch to full int.
AM Reacquired
AM Reacquired
AM Reacquired
AM Reacquired
7>/T
T>y
PhysCyl GrayCyl
First System Cylinder 0000F2EA 000107D0
First Zero Offset Cylinder 0000F2F4 000107DA
First App Code Cylinder 0000F2FF 000107E5
Second App Code Cylinder 0000F300 000107E6
Second Zero Offset Cylinder 0000F30B 000107F1
Third App Code Cylinder 0000F316 000107FC
Fourth App Code Cylinder 0000F317 000107FD
First Adaptives Cylinder 0000F318 000107FE
First User Defect List Cylinder 0000F319 000107FF
First Alternate Pool Cylinder 0000F31D 00010803
First Cert Code Cylinder 0000F331 00010817
First Intf Code Cylinder 0000F333 00010819
First Intf System Cylinder 0000F335 0001081B
First SEADEX Cylinder 0000F33A 00010820
First Cert Log Cylinder 0000F34C 00010832
First Decay Cylinder 0000F35C 00010842
First SPLASH Cylinder 0000F369 0001084F
Last System Cylinder 0000F369 0001084F
T>
T>N50,,22
Code - 33 Track 0F332.3.30B Sns 2F9 Rty F7FF.FF.80FF Rtf 1800 LBA 00000000
T>Age=50 Type=E3 MxCyl=17C5C MxHd=3 MxSct=370 BSz=2000 TCode=0000
T>
Thank you
Kib
Posted: 12.03.08, 14:24
by Max_ACELab
It`s PCB or heads problem. Not SysSect as surface object.
Try to use good PCB. If it`ll not help you, it is need to change heads.
Please, don`t try to write any data to HDD! You can damage Sys Sect. After that user data will be inaccessible at all!
