Seagate PCB swap between SATA and PATA drives
Posted: 27.11.07, 13:34
by dmarques
I have here a Seagate ST3320820A with damaged PCB, but I can only find in a supplier a ST3320820AS PCB with same firmware.
Anyone has already tested to check if theyaˆ™re compatible?
Posted: 23.01.08, 10:10
by Lux
did you try it? What results?
Thank you
Posted: 01.02.08, 11:09
by ACE_Admin
some of these drives has universal firmware for both SATA and PATA.
but for 100% compartibilty the drives should belong to same interfaces
