need short pin because busy but can appear F3 T>
jinarto
Postby jinarto » 21.04.15, 13:56
somebody help.
need pin short for this drive seagate st3250318as with pcb id : 100532367 Rev B
Thanks,
Jinarto
Thanks :D ,
Jinarto
rezafarah
Re: need short pin because busy but can appear F3 T>
Postby rezafarah » 21.04.15, 18:20
jinarto
Postby jinarto » 22.04.15, 07:14
Thank u very much rezafarah. i will try.
Thanks :D ,
Jinarto
jinarto
Postby jinarto » 22.04.15, 09:24
Hello Rezafarah,
thanks your information about short pin. i have been try but still busy and appear F3 T>
cannot clear smart or clear glist.
Need help
Thanks,
Jinarto
Thanks :D ,
Jinarto
rezafarah
Postby rezafarah » 25.04.15, 10:38
if F3 T> appear so use this command:
F3 T>/1
F3 1>N1
and this N1 will clear SMART manually.
Postby AJ2008 » 13.05.15, 11:56
rezafarah wrote:if F3 T> appear so use this command:
F3 T>/1
F3 1>N1
This may give you 'INIT SMART FAIL' error on this model.
