hi,
In this new update there is option we can retrive data from encrypted wd hdd.BUt pls anyone explain how to do that ?
is there any manual or methd we can read.
HDD
Are you still spending much time on WD USB data decryption?
We present the new fast and efficient “Decryption on the fly" method:
No need to make the full copy of the encrypted WD
No need to search for a compatible USB-SATA adapter
Just one-click!
but how ?
how to use on the fly decrypt
- datasolution
Re: how to use on the fly decrypt
1 - Open DE task
2- Set task with Data Copy Option
3 - Under Task parameters select the tab for command to read
4 - check box for 'Decryption'
5 - allow utility to autodetect Key, then accept it
6 - Now data will read as decrypted
- datasolution
hi aj,
thanks for fast reply.my drive is WDC WD10TMVW-11ZSMS1-01-01A01-WD-WX51AB0Axxxx .It does not get family.so first i need to convert it to sata and than create task with de ?
datasolution wrote:hi aj,
Yes, it needs to be SATA. Connected over USB data transfers through bridge and is already accessible in decrypted format. also, at USB some sectors are cut and there will be no key found at magic sector.
It needs to be SATA, then you will see option for decryption
