shorting points
eurlamp
shorting points
Postby eurlamp » 19.06.12, 15:30
I'm searching the shorting points for seagate pcb 100617465 on a ST2000DL001 drive. Isolating motor contacts doesn't work
thanks
François
einstein9
Re: shorting points
Postby einstein9 » 19.06.12, 17:34
Post clear image of the pcb here
eurlamp
Re: shorting points
Postby eurlamp » 20.06.12, 18:28
This is the pcb photo.
thanks
einstein9
Re: shorting points
Postby einstein9 » 21.06.12, 19:23
the image is not clear try this
eurlamp
Re: shorting points
Postby eurlamp » 27.06.12, 17:02
Thanks a lot for your answer. It is working now.
François
einstein9
Re: shorting points
Postby einstein9 » 27.06.12, 20:06
Glad to hear that
good luck :roll:
MrHopper
Re: shorting points
Postby MrHopper » 24.09.14, 11:25
hello.
Thank you for the information.
Only for info: shorting points also the same in PCB 100603204.
After using the shorting points I got access via terminal and made "Clear Smart" via terminal
F3 T> /1
F3 1> N1
switch off/on hdd, I got full access to the HDD
