Shorting Points for 100535704 Rev. C
digital
Postby digital » 24.01.13, 02:31
I have a Seagate ST3500413AS 7200-12, which sounds like it comes ready perfectly, but I cannot read a drive ID or capacity with the PC3K and I have no idea what the shorting points are on this PCB, it is not in the manual. Can anybody help me out with this?
Thank you for anything anybody has on this issue and drive! :P
carlosmar
Re: Shorting Points for 100535704 Rev. C
Postby carlosmar » 06.02.13, 20:53
I have the same problem, can anyone help us. thanks.
Postby AJ2008 » 07.02.13, 12:05
Best to post a picture of the PCB here
Arihant
Postby Arihant » 14.02.13, 06:38
attached the photos
Thanks,
Thanks,
Amit Shah
Arihant Data Recovery, India
Postby AJ2008 » 15.02.13, 15:50
Try this
short points
Arihant
Postby Arihant » 15.02.13, 16:55
try this
Thanks,
Amit Shah
Postby AJ2008 » 15.02.13, 18:23
The points I marked are horizontally aligned and are to the right of the screwhole. From other side, would be closest 2 horizontally aligned points to the left of the screwhole.
hddr49
Postby hddr49 » 10.07.14, 10:46
thank you AJ, and thank you search field :P
