ST1000DL002-9TT153 recover translator
NSRGroup
Postby NSRGroup » 03.05.13, 08:18
hdd model :st1000dl002-9tt153
fw: cc32
hdd work up to lba 468901856
but 468901856 to 1,953,525,168 alll sector error
with recover translator
"Fork" searching: 468901856 - 1953525167
Verify sectors ext error Device error detected "UNC"
Surface scanning error (instability)
LBA : 468901856
"Fork" searching: 468901857 - 1953525167
LBA : 468901857
"Fork" searching: 468901858 - 1953525167
LBA : 468901858
"Fork" searching: 468901859 - 1953525167
LBA : 468901859
"Fork" searching: 468901860 - 1953525167
LBA : 468901860
"Fork" searching: 468901861 - 1953525167
LBA : 468901861
"Fork" searching: 468901862 - 1953525167
LBA : 468901862
"Fork" searching: 468901863 - 1953525167
LBA : 468901863
"Fork" searching: 468901864 - 1953525167
LBA : 468901864
"Fork" searching: 468901865 - 1953525167
LBA : 468901865
"Fork" searching: 468901866 - 1953525167
LBA : 468901866
"Fork" searching: 468901867 - 1953525167
LBA : 468901867
"Fork" searching: 468901868 - 1953525167
LBA : 468901868
"Fork" searching: 468901869 - 1953525167
LBA : 468901869
"Fork" searching: 468901870 - 1953525167
LBA : 468901870
"Fork" searching: 468901871 - 1953525167
LBA : 468901871
"Fork" searching: 468901872 - 1953525167
LBA : 468901872
"Fork" searching: 468901873 - 1953525167
LBA : 468901873
"Fork" searching: 468901874 - 1953525167
LBA : 468901874
"Fork" searching: 468901875 - 1953525167
LBA : 468901875
"Fork" searching: 468901876 - 1953525167
LBA : 468901876
"Fork" searching: 468901877 - 1953525167
LBA : 468901877
"Fork" searching: 468901878 - 1953525167
LBA : 468901878
"Fork" searching: 468901879 - 1953525167
LBA : 468901879
"Fork" searching: 468901880 - 1953525167
LBA : 468901880
"Fork" searching: 468901881 - 1953525167
LBA : 468901881
"Fork" searching: 468901882 - 1953525167
LBA : 468901882
"Fork" searching: 468901883 - 1953525167
LBA : 468901883
"Fork" searching: 468901884 - 1953525167
LBA : 468901884
"Fork" searching: 468901885 - 1953525167
LBA : 468901885
"Fork" searching: 468901886 - 1953525167
LBA : 468901886
"Fork" searching: 468901887 - 1953525167
LBA : 468901887
"Fork" searching: 468901888 - 1953525167
LBA : 468901888
"Fork" searching: 468901889 - 1953525167
LBA : 468901889
"Fork" searching: 468901890 - 1953525167
LBA : 468901890
"Fork" searching: 468901891 - 1953525167
LBA : 468901891
"Fork" searching: 468901892 - 1953525167
LBA : 468901892
"Fork" searching: 468901893 - 1953525167
LBA : 468901893
"Fork" searching: 468901894 - 1953525167
LBA : 468901894
"Fork" searching: 468901895 - 1953525167
LBA : 468901895
"Fork" searching: 468901896 - 1953525167
LBA : 468901896
"Fork" searching: 468901897 - 1953525167
LBA : 468901897
"Fork" searching: 468901898 - 1953525167
LBA : 468901898
"Fork" searching: 468901899 - 1953525167
LBA : 468901899
"Fork" searching: 468901900 - 1953525167
LBA : 468901900
"Fork" searching: 468901901 - 1953525167
LBA : 468901901
"Fork" searching: 468901902 - 1953525167
LBA : 468901902
"Fork" searching: 468901903 - 1953525167
LBA : 468901903
"Fork" searching: 468901904 - 1953525167
LBA : 468901904
"Fork" searching: 468901905 - 1953525167
LBA : 468901905
"Fork" searching: 468901906 - 1953525167
LBA : 468901906
"Fork" searching: 468901907 - 1953525167
LBA : 468901907
"Fork" searching: 468901908 - 1953525167
LBA : 468901908
"Fork" searching: 468901909 - 1953525167
LBA : 468901909
"Fork" searching: 468901910 - 1953525167
LBA : 468901910
"Fork" searching: 468901911 - 1953525167
LBA : 468901911
"Fork" searching: 468901912 - 1953525167
LBA : 468901912
"Fork" searching: 468901913 - 1953525167
LBA : 468901913
"Fork" searching: 468901914 - 1953525167
LBA : 468901914
"Fork" searching: 468901915 - 1953525167
LBA : 468901915
"Fork" searching: 468901916 - 1953525167
LBA : 468901916
"Fork" searching: 468901917 - 1953525167
LBA : 468901917
"Fork" searching: 468901918 - 1953525167
LBA : 468901918
"Fork" searching: 468901919 - 1953525167
LBA : 468901919
"Fork" searching: 468901920 - 1953525167
LBA : 468901920
"Fork" searching: 468901921 - 1953525167
LBA : 468901921
"Fork" searching: 468901922 - 1953525167
LBA : 468901922
"Fork" searching: 468901923 - 1953525167
LBA : 468901923
"Fork" searching: 468901924 - 1953525167
LBA : 468901924
"Fork" searching: 468901925 - 1953525167
LBA : 468901925
"Fork" searching: 468901926 - 1953525167
LBA : 468901926
"Fork" searching: 468901927 - 1953525167
LBA : 468901927
"Fork" searching: 468901928 - 1953525167
LBA : 468901928
"Fork" searching: 468901929 - 1953525167
LBA : 468901929
"Fork" searching: 468901930 - 1953525167
LBA : 468901930
"Fork" searching: 468901931 - 1953525167
LBA : 468901931
"Fork" searching: 468901932 - 1953525167
LBA : 468901932
"Fork" searching: 468901933 - 1953525167
LBA : 468901933
"Fork" searching: 468901934 - 1953525167
LBA : 468901934
"Fork" searching: 468901935 - 1953525167
LBA : 468901935
"Fork" searching: 468901936 - 1953525167
LBA : 468901936
"Fork" searching: 468901937 - 1953525167
LBA : 468901937
"Fork" searching: 468901938 - 1953525167
LBA : 468901938
"Fork" searching: 468901939 - 1953525167
LBA : 468901939
"Fork" searching: 468901940 - 1953525167
LBA : 468901940
"Fork" searching: 468901941 - 1953525167
LBA : 468901941
"Fork" searching: 468901942 - 1953525167
LBA : 468901942
"Fork" searching: 468901943 - 1953525167
LBA : 468901943
"Fork" searching: 468901944 - 1953525167
LBA : 468901944
"Fork" searching: 468901945 - 1953525167
LBA : 468901945
"Fork" searching: 468901946 - 1953525167
LBA : 468901946
then if i stop and then check surface with mhdd again from 468901856 up to end all sector error
pls guide me for solution
Re: ST1000DL002-9TT153 recover translator
Postby AJ2008 » 03.05.13, 13:58
Did you record entries at NRG before you run translator regen?
NSRGroup
Postby NSRGroup » 03.05.13, 16:17
hi AJ2008
thanks for answer
in terminal
when time running translator recover
ProcessRWError -Read- at LBA 039180D3 Sense Code=C4090082
Starting LBA of RW Request=039180D3 Length=FFFFFFFF
Starting LBA of RW Request=039180D4 Length=FFFFFFFF
ProcessRWError -Read- at LBA 039180D4 Sense Code=C4090082
ProcessRWError -Read- at LBA 039180D4 Sense Code=43110081
Starting LBA of RW Request=039180D5 Length=FFFFFFFF
ProcessRWError -Read- at LBA 039180D5 Sense Code=43110081
ProcessRWError -Read- at LBA 039180D5 Sense Code=C4090082
Starting LBA of RW Request=039180D6 Length=FFFFFFFF
ProcessRWError -Read- at LBA 039180D6 Sense Code=C4090082
ProcessRWError -Read- at LBA 039180D6 Sense Code=43110081
Starting LBA of RW Request=039180D7 Length=FFFFFFFF
ProcessRWError -Read- at LBA 039180D7 Sense Code=C4090082
ASCII Diag mode
i stoped work and
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>V40
Total entries available: 0
glist is empty
I disable auto reassian in edit hdd id
reference (( at page 12 in manual seagate , part F3 architecture ))
am i doing mistake work?
Postby AJ2008 » 07.05.13, 11:56
Did you make translator regeneration before?
NRG list now is empty, but maybe before it had defects inside it that are not lost?
NSRGroup
Postby NSRGroup » 08.05.13, 15:07
thanks for answer AJ2008
i do'nt make tranlator regeneration before ,
i think tranlator in some new 7200.12 drive different with older 7200.12
how ever this command is not worked with min 2 hdd in this family with my exprience
:cry:
Postby AJ2008 » 08.05.13, 15:25
If translator hasnt been re-built, and pending operations are disabled, considering you have full ID and some access, I dont see reason why full access is not possible.
Can you try (in DE task) to select option 'Work with Active utility', when prompted to transmit data in spite of error, select 'No'. Now try to read some sector at end of the disk, some sector where couldnt read before.
