Hitach-Ibm-ARM 5475A9 , 500 GB
The drive originally is not detected. When logging to Utility, and Loading modules, it worked, identified, and all critical modules are okay. Heads are okay.
When I start Cloning, when it find a bad sector, it loses readiness, I reload modules, and copy again. Bad sectors are very few, only 3.
After sector 95 000 000, it cannot close, only black holes Sectors. It seems to me that it is like Seagate Momentus Problem, after certain sector it is not working.
Any info about this problem?
Re: Hitach-Ibm-ARM 5475A9
I think you have already changed heads and donor not fully compatible
No, It is not opened yet
I think ACE team should work on this issue, I am sure that it is translator Issue, like the seagate 2.5 " translator problem
