7200.12 CC66 ST3500418AS
scott
Postby scott » 14.03.12, 23:56
Drive spins, sounds normal, immediately:
Code: Select all
Rst 0x10M
Seen this a few times before, typically just regen translator and we're good to go, not on this guy.
Regen translator runs and completes without error. Still BSY in terminal with same error message.
Cleared GLIST to no effect and without error. Regen'd, still no joy.
Trying to run N1 command to clear smart gives a
Code: Select all
Init SMART Fail
LED:000000CC FAddr:0024E59
BUT if I run the N1 command immediately after a regen without killing power it actually says it cleared the SMARTs without error. But even after successfully clearing the Smart it still gives the No HOST FIS and is a brick.
Code: Select all
New Skews Pharaoh 0F with VTPI,RAP16,Common Code 6
Product FamilyId: 3F, MemberId: 05
HDA SN: 5VM9RMQA, RPM: 7201, Wedges: 120, Heads: 2, Lbas: 3A386030, PreampType: 73 23
PCBA SN: 0000E035A48K, Controller: YETIST_3_0(649B)(3-12-3-3), Channel: AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 94, BufferBytes: 1000000
Package Version: PH0G2D.CCD6.EC016V., Package P/N: 100591807, Package Builder ID: AT,
Package Build Date: 09/11/2009, Package Build Time: 17:03:00, Package CFW Version: PH0G.CCD6.00203193.AT00,
Package SFW1 Version: D24D, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 09111703, CustomerRel: CC66, Changelist: 00203193, ProdType: PH0G.CCD6, Date: 09/11/2009, Time: 170300, UserId: 00236537
Servo FW Rev: D24D
RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 09 08 03
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled
- LTTC-UDR2 enabled
This is a very important customer of mine in a real pickle. First time poster here. Any ideas?
scott
Re: 7200.12 CC66 ST3500418AS
Postby scott » 15.03.12, 00:18
After reading a couple related posts I wanted to share this addition information:
The S/N on the drive is 5VM9RMQA (same as I get with CTRL-L). Am I correct in assuming CTRL-L output is exporting the S/N from the PCB ROM and not the platter so I can rule out the customer sending the wrong PCB?
Code: Select all
ASCII Diag mode
F3 T>V1
 User Slip Defect List
                         log log   log     phys   phys
    LBA    span   cumm   cyl  hd  sctr zn   cyl   sctr     SFI      PBA
       0      0      0     0  0     0   0      0     0        4        0
Head 0: entries      1        slips        0
Head 1: entries      0        slips        0
  Total Entries      1  Total Slips        0
F3 T>/1
F3 1>N6
Att  Thresh
  1      6
  3      0
  4     14
  5     24
  7     1E
  9      0
  A     61
  C     14
 B7      0
 B8     63
 BB      0
 BC      0
 BD      0
 BE     2D
 C2      0
 C3      0
 C5      0
 C6      0
 C7      0
 F0      0
 F1      0
 F2      0
  0      0
  0      0
  0      0
  0      0
  0      0
  0      0
  0      0
  0      0
F3 1>N8
                                              DERP
  dec                                         error  DERP
 Hours -     LBA       R  Theta Z EC       Cmd type  retry temp count  type
F3 1>
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewrite Retries = 2DF8
User Partition Format Successful - Elapsed Time 0 mins 00 secs
F3 T>
InitiateMarkPendingReallocateRequest for disc_lba: 0000012F
InitiateMarkPendingReallocateRequest for disc_lba: 00000130
InitiateMarkPendingReallocateRequest for disc_lba: 00000131
InitiateMarkPendingReallocateRequest for disc_lba: 00000132
InitiateMarkPendingReallocateRequest for disc_lba: 00000133
InitiateMarkPendingReallocateRequest for disc_lba: 00000134
InitiateMarkPendingReallocateRequest for disc_lba: 00000135
