ST32000542AS errs: Add2Alt: invalid LBA = -2038076722
drdoc
Postby drdoc » 03.02.12, 20:28
I have a seagate 2tb.
Recovering translator gets weird error Add2Alt: invalid LBA = -2038076722
This occurs in the defects list report after recovery when I do "hide to slip-list" command.
sw build 4.3.0.964
Below is the defect list.
Model : ST32000542AS
Serial : 5XW01HJB
Firmware : CC32
Capacity : 1 863.02 GB (3 907 029 168)
Test : Recover translator
Start from LBA.................................... : 148980506
Translation "forks" list file..................... : E:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\F3 Arch (common)\ST32000542AS-CC32-5XW01HJB\Defects\TranslationForks.lba
Maximal defect chain length....................... : 64
Take into account P-List.......................... : Yes
At ambiguity hide "left" UNC...................... : No
HDD ID reading...
Detecting defects hiding cmd type...
G-List erase...
Detecting Phys Sct Size...
Start scanning...
"Fork" searching: 148980506 - 3907029167
Verification error 48-bit (UNC)
"Right fork", LBA = 00256997331, pattern 0x00
Defects hiding (P)...
Moving defects to Slip-List...
Translator regeneration...
"Fork" searching: 256997331 - 3907029167
"Right fork", LBA = 01199885123, pattern 0x00
"Fork" searching: 1199885123 - 3907029167
"Right fork", LBA = 02256890476, pattern 0x00
"Fork" searching: 2256890476 - 3907029167
Translator recovering is completed!
Test : Hiding defects to Slip-List
G-List erase...
G-List erase...
NN : Init. LBA : Fin. LBA : Num : Filling Pattern
1 : 21 838 617 : 21 838 617 : 1 : 0
2 : 148 980 497 : 148 980 497 : 1 : 0
3 : 148 980 507 : 148 980 535 : 29 : 0
4 : 148 980 537 : 148 980 601 : 65 : 0
5 : 256 997 427 : 256 997 427 : 1 : 0
6 : 1 199 885 220 : 1 199 885 220 : 1 : 0
7 : 2 256 890 574 : 2 256 890 574 : 1 : 0
skype: wayne_horner
Alandata Data Recovery
drdoc
Re: ST32000542AS errs: Add2Alt: invalid LBA = -2038076722
Postby drdoc » 03.02.12, 20:50
after deleting the last # in the defect list
it then worked....
G-List erase...
Completed!
The problem is apparently
skype: wayne_horner
drdoc
Postby drdoc » 03.02.12, 20:57
and the translator recover didnt work.
can read at 148M
but not past
skype: wayne_horner
