seagate 5400.6 st9500325as
check modules 19 AND 2b is can't read
Can i write other 5400.6 ok module to replace it?
many thanx
5400.6 MODULE 2B BAD (SOLVE)
Re: 5400.6 MODULE 2B BAD
What happens when you are trying to regenerate translator?
I advise to do next :
T>m0,6,2,,,,,22
then press ctrl-T and reread ID with ctrl-p . Very likely drive will show you ID. Then try to image it.
T>m0,6,2,,,,,22
Thanks for ACELab support
The driver can decteted all size by UDMA,
When DE from 0-261306913 is ok
But 261306914-976773167 is can't read
Can you givet me some instructions?
I use translator recovery method with http://acelaboratory.ru/forum/viewtopic.php?f=34&t=7316&sid=e2c237a9935c67c1cf4e66fee9f07735
Then another harddisk st9500325as can access to user data.
But This module 2b bad harddisk (st9500325as) have error message like
HDD ID reading...
Detecting defects hiding cmd type...
G-List erase...
Detecting Phys Sct Size...
Start scanning...
"Fork" searching: 136300000 - 976773167
Verification error 48-bit (UNC)
PRd: Err Rd Ph Sect 822F:3:1E9(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 822F:3:1E9(1)! Tech state 0x72, 0x03110081
LBA : 261306914
"Fork" searching: 261306915 - 976773167
Translation "fork" direction detection ambiguity!
Correct it manually!
LBA : 261306915
HDD ID reading...
G-List erase...
Start scanning...
LBA : 261306914
LBA : 261306915
Very thans for Roustam
I recovery data by DE now!
