ST3250318AS HP35 Urgent recovery
rirureta
Postby rirureta » 02.12.11, 00:14
Hi friends,
I have this drive with the BSY problem, after repair this issue i cant recover the data and do an image neither because the drive runs bloody slowly.
Do you have any solution?
Re: ST3250318AS HP35 Urgent recovery
Postby ACE_Admin » 06.12.11, 09:54
Is it possible to save modules on this drive?
Also, tell if it is possible to reach terminal output? What messages came out when you try to read surface?
Please make all modules backup and turn off all "Pending" and "Defects Reassigment" options with "Edit HDD ID" window.
It is located in Tests->Service information->Work with SA->Edit HDD ID. Turn off all parameters, except "Show additional diag msg in terminal"
Users browsing this forum: Bing [Bot] and 1 guest
