please help me !!!!!!!!
mojimorady
Postby mojimorady » 19.12.10, 19:04
hi guru
i have a hdd as follow :
1TB , seagate sata
model :ST31000520AS
Firmware : CC32 , Barracuda LP
when i connect it to pc3000 , it remains on busy . i tried the soloutions for seagate F3 family but
nothing happened .
i tried to unlock the with hyper terminal but it says :
ASCII Diag mode
F3 T>/2
F3 2>
No HOST FIS-ReadyStatusFlags 2002B001Z
HighPowerMode 0027
Spin Down Complete
Elapsed Time 0.100 msecs
F3 2>U
HighPowerMode 002F
ExecuteSpinRequest
Spin Up Complete
Elapsed Time 5.251 secs
F3 2>/1
F3 1>N1
Init SMART Fail
LED:000000CC FAddr:0024EE21
now please someone show me any soloution to solve the problem
faithfully yours
moji morady
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
dmarques
Re: please help me !!!!!!!!
Postby dmarques » 21.12.10, 09:52
Did you check if the PCB is native?
mojimorady
Postby mojimorady » 22.12.10, 14:39
dear Datalabace
hi
yes i checked , the pcb is the original one ,
now i want to know does it need to change heads ?
regards
Mojtaba Morady
dmarques
Postby dmarques » 22.12.10, 15:44
If PCB is native, then you should swap heads.
mojimorady
Postby mojimorady » 25.12.10, 18:20
dear datalabace
accept my regards
i changed the head , and i screw the donor pcb , should i use the native ROM
or the donor ROM ?
best wishes
moji
Mojtaba Morady
Issam
Postby Issam » 25.12.10, 22:20
1- If the native pcb does not help after heads swapping , then
2- Solder the native Rom on the donor pcb, and check, if this does not work
3- Most likely the native heads damaged the SA on the platters, and scratcded them, then
4-The case is un recoverable.
Feed me back, please
mojimorady
Postby mojimorady » 26.12.10, 08:18
dear issam
tnx so much for your helpful lines
1- i used the native pcb and native rom (i did not change the rom ) but it makes sounds like clicking
2- i used the donor pcb + native rom = again that sound
3- i used native pcb + donor rom = there is no sound , but when it wants to detect , it makes the starnge sound
please note that the head was swapped
regards
moji
Mojtaba Morady
Issam
Postby Issam » 26.12.10, 13:06
I faced such cases,
1-Do the native heads show obvious damage on them, especially head 0, ? (the first one from the bottom), check with the aid of a magnifier.
IF so, I am sorry to tell you (based on my experience), the Service area is scratched, and there is no method for the time being that helps.
mojimorady
Postby mojimorady » 26.12.10, 16:24
dear Issam
all the heads were apparently ok
maybe it is one of the starngest case in data recovery field !!!
may i have your email address ?
this is mine : mojimorady@msn.com
regards
Mojtaba Morady
Issam
Postby Issam » 26.12.10, 20:19
check your mail. Please.
