I have tried self scan for remove the bad sectors. After finishing the Self Scan the drive is not detecting, i have restore the CERT Code and HDD ID template also, but there is no use.
Drive details as below
ST380011A
Firmware:-8.01
With regards
Datacare
ST380011A- Self Scan Problem
Re: ST380011A- Self Scan Problem
Can I have the logs from terminal, this drive show you?
I got the following Termial log
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M-21 11-25-03 18:53
Head Mask FFFF - Switch to full int.
Spin Ready
8.01 04-05-04 15:38
(P)PATA Reset
Not Interface Age!
VALID Cert Disk Code Detected - Revision # .248
Cert Table loaded
No script first instruction.
No valid SeaDex script on disc.
Begin Test 08
Not Power Cycling
SkpCylList deleted
Sys= 0E940-0E9BF 0280 SPTK on sys trks
<empty>
drive must be reformatted
Skipping MDW oversample s/n cylinders.
Spin Ready
8.01 04-05-04 15:38
(P)PATA Reset
Not Interface Age!
Cert Table loaded
Begin Test 08
Not Power Cycling
SkpCylList deleted
<empty>
Users browsing this forum: Bing [Bot] and 13 guests
