ST9500420AS
sempre
ST9500420AS
Postby sempre » 28.05.10, 15:17
Hi to all!! :mrgreen:
this HDD very slow to get ready, strange sounds while trying to read the data, are apparently many bad blocks with reollocated very high, but when trying to test the route heads F3 ERROR LED=> LED:000000CE FAddr:00263339 :shock: I think that command should be not compatible.
It also found that these modules are bads. BAD MODULES
0E
2F
22
Question: This problem of reading the hds are really bads blocks or problems with the modules? Or finally the heads? => I do not believe that is still bad heads
Any help would be appreciated ... :?:
nothing is impossible!
