i have a ST9120822AS 3.ALD drive and after start of App code it reports following (see below) so I am ot able to read ID and access the sectors. Is there any way ? I am able to create the loader and read whole SA without any problem.
Unfortunately i was not able to get any ST9120822AS 3.ALD loader from different drive (all have different FW) to try change App code (will it help?).
I also tried to modify the App by DE but it does not help either.
Eng Rev = .03F
Compat/Hardware = .4F3
VENUS - 2_Disk 3.ALD 04-20-07_16:10 ALC,VE_2D_4H_S,2Y
CERT Rev = .027
NONE
Mask Rom Rev = S-0C
Orig Code = ALC2Y0
Reset
4096k x 16 DRAM
VENUS - 1_Disk M-37 12-01-06_14:56
Buzz HM SFI
F>R
Buzz HM SFI
F>j
(P)Failed sys sect. write
SATA Reset
Restore
(H)
CorrectWriteStart
AT Er 00 Nwt Er 7b RdWr 0a31f.01.02e5
ATA St 80 Er 00 Op 00 0,0000/0/00,00 01 00
Niwot: 07f6fff0 14 07f6fff0.0.000 8000 053d 0020 0000
CE Log ErrCode=7b LBA=7f6fff7 Type=0Failed sys sect. write
Corrected write failed EC7b
Failure of 07f6fff7 cant be fixed
CE Log ErrCode=7b LBA=7f6fff7 Type=1Failed sys sect. write
CorrectWriteStart
AT Er 00 Nwt Er 7b RdWr 0a31f.01.02e6
Niwot: 07f6fff8 14 07f6fff8.0.000 8000 0545 0020 0000
CE Log ErrCode=7b LBA=7f6fff8 Type=0Failed sys sect. write
Failure of 07f6fff8 cant be fixed
CE Log ErrCode=7b LBA=7f6fff8 Type=1Failed sys sect. write
CorrectWriteStart
AT Er 00 Nwt Er 7b RdWr 0a31f.01.02e7
Niwot: 07f6fff9 14 07f6fff9.0.000 8000 0546 0020 0000
CE Log ErrCode=7b LBA=7f6fff9 Type=0Failed sys sect. write
Failure of 07f6fff9 cant be fixed
CE Log ErrCode=7b LBA=7f6fff9 Type=1Failed sys sect. write
And so on in a loop ....
ST9120822AS 3.ALD App problem
Re: ST9120822AS 3.ALD App problem
looks like a CE Error log problem. With DE you should be able to fix this, I think.
I you haven't already read this you might want to have a look here:
"7200.10 ST3250310AS CE log"
viewtopic.php?f=34&t=6551
and here:
"CE log errcode"
viewtopic.php?f=34&t=6915
Good luck!
and here:
"CE log errcode"
Good luck!
Hi, thanks for you reply, but as i wrote "I also tried to modify the App by DE but it does not help either." Means i allready tried the App modifications.
The process of modified App start does not finish. It reports following in a loop:
ROM image reading...
Test : HDD initialization by utility...
Switch HDD PWR supply.... : No
Terminal Reset........... : No
Terminal work speed...... : 921000
Used LDR................. : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Momentus (Venus)\1495-test1\Data\LDR\SgLDR.ldr
Loaded from.............. : E:\DE-TASKS\1495\LDR\SgLDR_Manual.ldr
Work with HDD through.... : ATA
App...................... : Loading from LDR
Used modifications....... : Fix 'Pending Bug', Fix 'Pending Bug' (fix 2), Fix 'Not Handled Soft Path' Bug, Disable SysSect write, Alow ATA LBA->PCHS conversion
Load Ovl 0............... : No
Initializing Safe Mode...
Switching HDD power supply ON
Loading App Loader...
App patching...
Downloading App code...
App code downloading.................... : Ok
HDD SpinUp.............................. : Ok
Reading boot SA elements...
Reading boot adaptives.................. : Ok
Reading Reserve track defect list....... : Ok
Starting App code...
(P
cmd 2A, params 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
cmd 58, params 0036 0000 0000 0001 3F87 0001 0000 0000 0000 D8FC 0036
cmd 58, params 0036 0000 0001 0093 3F00 0093 0000 0000 0036 0000 0036
cmd 36, params 0006 0000 0003 0047 6F60 7F01 0001 3059 322E 6731 7FFF
cmd 58, params 0038 0000 0004 0001 3FE0 0001 0000 0000 6001 7F01 0038
cmd 36, params 0000 0038 0000 0004 7FFF 0050 00ED 0010 0000 0000 0000
cmd 36, params 0006 0000 0030 0000 1070 7F01 0001 0000 0000 0000 7F01
cmd 58, params 0039 0000 0241 0001 3FE0 0001 0000 0000 6001 7F01 0039
cmd 36, params 0000 0039 0000 0241 7F01 4981 00ED 5E63 A831 0400 0000
cmd 36, params 0006 0000 0006 02E1 3FE0 FD01 0001 7F01 0000 0001 FD00
cmd 58, params 0038 0000 0007 0001 3FE0 0001 0000 0000 6001 FD01 0038
cmd 36, params 0000 0038 0000 0007 FD00 005C 00ED 005C 00ED 0010 0000
cmd 36, params 0006 0000 0001 6001 FD01 FD01 0001 0000 0038 0000 FD01
cmd 58, params 0038 0000 0002 0001 3FE0 0001 0000 0000 6001 FD01 0038
cmd 36, params 0000 0038 0000 0002 FD01 000C 00ED FD00 000C 00ED 0010
cmd 36, params 0006 0000 000A 110C 02BA 0501 0001 7EE2 0000 0000 0501
cmd 58, params 0038 0000 0018 0001 3FE0 0001 0000 0000 6001 0501 0038
cmd 36, params 0000 0038 0000 0018 0501 0000 007F FD00 000C 00ED 0010
cmd 36, params 0006 0000 0005 0501 0001 4B01 0001 0038 0000 0018 4B00
cmd 58, params 0038 0000 0006 0001 3FE0 0001 0000 0000 6001 4B01 0038
cmd 36, params 0000 0038 0000 0006 4B00 0000 007F 4B00 007C 00ED 0010
cmd 36, params 0006 0000 0001 007F 4B00 4B01 0001 0010 0000 0000 4BB0
cmd 58, params 0038 0000 0002 0001 3FE0 0001 0000 0000 6001 4B01 0038
cmd 36, params 0000 0038 0000 0002 4BB0 4981 00ED 4981 5E63 A831 0400
cmd 6C, params 4981 5E63 A831 0400 0000 8000 0000 0400 A831 5E63 0000
SATA Reset
cmd 36, params 0300 5E63 A831 0400 0000 8001 0000 0400 A831 5E63 0000
cmd 36, params 0006 0000 002D 4981 0401 7D01 0001 001D 37B4 0036 7DE7
cmd 58, params 0039 0000 023E 0001 3FE0 0001 0000 0000 0036 7D01 0039
cmd 36, params 0000 0039 0000 023E 7DE7 0000 007F 4981 00ED 5E63 A831
cmd 58, params 003D 0000 0000 0001 3FE0 0001 0000 0000 0001 003D 003D
cmd 58, params 003D 0000 0001 0186 03DF 0186 0000 0000 0001 0186 003D
Restore
cmd 36, params 0000 5E63 A831 0400 0000 8001 0000 0400 A831 5E63 0000
(H)
cmd 14, params FFF0 07F6 0000 8000 053D 0020 0000 0000 0000 0001 0000
CorrectWriteStart
cmd 36, params 0006 0000 0018 0000 CF7B 0001 0001 0617 0078 007B 0000
cmd 58, params 0038 0000 0060 0001 3FE0 0001 0000 0000 6001 0001 0038
cmd 36, params 0000 0038 0000 0060 0000 FFF7 07F6 0033 0000 07F6 D902
cmd 36, params 0006 0006 0018 0001 0001 0001 0001 0038 1BF0 2B5F 0000
cmd 58, params 0038 0000 0066 0001 3FE0 0001 0000 0000 6001 0001 0038
cmd 36, params 0000 0038 0000 0066 0000 0000 0060 0033 0000 07F6 2B5F
cmd 3C, params 14F0 0000 1000 0000 0000 0000 0000 0000 0000 0000 0000
cmd 3C, params 25BC 0000 1000 0000 0000 0000 0000 0000 0000 0000 0000
cmd 3C, params 3AA2 0000 1000 0000 0000 0000 0000 0000 0000 0000 0000
cmd 3C, params 533E 0000 1000 0000 0000 0000 0000 0000 0000 0000 0000
cmd 3C, params 7058 0000 1000 0000 0000 0000 0000 0000 0000 0000 0000
cmd 3C, params 8570 0000 1000 0000 0000 0000 0000 0000 0000 0000 0000
cmd 3C, params A096 0000 1000 0000 0000 0000 0000 0000 0000 0000 0000
cmd 3C, params B7A2 0000 1000 0000 0000 0000 0000 0000 0000 0000 0000
cmd 3C, params D61A 0000 1000 0000 0000 0000 0000 0000 0000 0000 0000
cmd 6C, params 0000 FFF7 07F6 007B 0000 CF01 003C 0000 FB00 0000 1908
Remove from Pending 7f6fff7
cmd 36, params 0006 0000 001B 07F6 D8CE FF01 0001 0000 007F 0708 FFF7
cmd 58, params 0038 0000 00ED 0001 3FE0 0001 0000 0000 6001 FF01 0038
cmd 36, params 0000 0038 0000 00ED FFF7 0000 007F 0000 0000 0006 0000
cmd 14, params FFF7 07F6 0000 0001 0544 0020 0000 0000 0000 0001 0000
Failure of 07f6fff7 can't be fixed
cmd 36, params 0006 0000 0018 0001 CF7B 0001 0001 0617 0078 007B 0001
cmd 58, params 0038 0000 0060 0001 3FE0 0001 0000 0000 0036 0001 0038
cmd 36, params 0000 0038 0000 0060 0001 FFF7 07F6 00C4 3B80 2C6E 0313
cmd 36, params 0006 0006 0018 0001 0001 0001 0001 0038 1BF0 2B5F 0001
cmd 36, params 0000 0038 0000 0066 0001 0000 0060 00C4 3B80 2C6E 2B5F
cmd 6C, params 3B80 FFF7 07F6 007B 0000 CF01 003C 8000 FB00 CF00 1908
Add To Pending 7f6fff7
cmd 36, params 0006 0000 001B 07F6 D8C4 0001 0001 0001 007F 0723 0001
cmd 58, params 0038 0000 00ED 0001 3FE0 0001 0000 0000 6001 0001 0038
cmd 36, params 0000 0038 0000 00ED 0001 0001 007F 0000 0006 006C 0000
cmd 14, params FFF8 07F6 0000 8000 0545 0020 0000 0000 0000 0001 0000
CorrectWriteStart
And so on ...
App patching...
(P
SATA Reset
Restore
(H)
CorrectWriteStart
CorrectWriteStart
And so on ...
Oops sorry.
Still: "Add to pending" sound like CE Error to me. Are you able to get into T> mode?
I know T4E might be a bad idea but it always helped me so far.
What exactly does the T>T4E command do? I only know the T>T4 as heads test.
updated:oh, i see. it should re-write the cert log. let me try.
OK, I tried, but it di dnot help. i still get the same errors as in my first post.
Anybody knows what the CE Log ErrCode=7b means? It's not documented in PC3K manual.
T>T4E
Command Inactive - No VALID Cert Code Detected
T>VALID Cert Disk Code Detected - Revision # .027
T>T4E
Begin Test 4E
Cert Table loaded
ASCII logging on
Not Power Cycling
ASCII logging off
ASCII logging on
Log 02 - Health 0019 - HlthDtl 0003 - Time = 02:05:13 Log Type = 01
Log 04 - Health 0000 - HlthDtl 0000 - Time = 00:12:01 Log Type = 01
Log 83 - Health 0000 - HlthDtl 0000 - Time = 00:06:02 Log Type = 01
Log 84 - Health 0000 - HlthDtl 0000 - Time = 00:00:35 Log Type = 01
Log 03 - Health 0000 - HlthDtl 0000 - Time = 00:25:41 Log Type = 01
Log 8A - Health 0000 - HlthDtl 0000 - Time = 00:05:41 Log Type = 01
Disc Operation failed
Log 05 - Health 0000 - HlthDtl 0000 - Time = 00:00:13 Log Type = 01
Log 06 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 07 - Health 0000 - HlthDtl 0000 - Time = 00:00:26 Log Type = 01
Log 90 - Health 0000 - HlthDtl 0000 - Time = 00:13:09 Log Type = 01
Log 93 - Health 0000 - HlthDtl 0000 - Time = 00:13:52 Log Type = 01
Log 98 - Health 0000 - HlthDtl 0000 - Time = 00:14:16 Log Type = 01
Log 9C - Health 0000 - HlthDtl 0000 - Time = 00:18:07 Log Type = 01
Log AA - Health 0000 - HlthDtl 0000 - Time = 00:18:04 Log Type = 01
Log 81 - Health 0000 - HlthDtl 0000 - Time = 00:36:01 Log Type = 01
Log 09 - Health 0000 - HlthDtl 0000 - Time = 00:33:07 Log Type = 01
Log 74 - Health 0000 - HlthDtl 0000 - Time = 00:24:30 Log Type = 01
Log F4 - Health 0000 - HlthDtl 0000 - Time = 00:02:19 Log Type = 01
Log 0F - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 01
Log 82 - Health 0000 - HlthDtl 0000 - Time = 00:01:55 Log Type = 01
Log 94 - Health 0000 - HlthDtl 0000 - Time = 00:00:34 Log Type = 01
Log 99 - Health 0000 - HlthDtl 0000 - Time = 00:00:01 Log Type = 01
Log 10 - Health 0000 - HlthDtl 0000 - Time = 00:14:11 Log Type = 01
Log 11 - Health 0000 - HlthDtl 0000 - Time = 00:12:09 Log Type = 01
Log 12 - Health 0000 - HlthDtl 0000 - Time = 00:11:55 Log Type = 01
Log 13 - Health 0000 - HlthDtl 0000 - Time = 00:13:17 Log Type = 01
Log 14 - Health 0000 - HlthDtl 0000 - Time = 00:12:06 Log Type = 01
Log 15 - Health 0000 - HlthDtl 0000 - Time = 00:16:33 Log Type = 01
Log 16 - Health 0000 - HlthDtl 0000 - Time = 00:13:23 Log Type = 01
Log 17 - Health 0000 - HlthDtl 0000 - Time = 00:13:27 Log Type = 01
Log 18 - Health 0000 - HlthDtl 0000 - Time = 00:14:39 Log Type = 01
Log 19 - Health 0000 - HlthDtl 0000 - Time = 00:16:03 Log Type = 01
Log 1A - Health 0000 - HlthDtl 0000 - Time = 00:13:34 Log Type = 01
Log 1B - Health 0000 - HlthDtl 0000 - Time = 00:13:27 Log Type = 01
Log 1C - Health 0000 - HlthDtl 0000 - Time = 00:13:21 Log Type = 01
Log 1D - Health 0000 - HlthDtl 0000 - Time = 00:12:03 Log Type = 01
Log 1E - Health 0000 - HlthDtl 0000 - Time = 00:13:29 Log Type = 01
Log 2A - Health 0000 - HlthDtl 0000 - Time = 00:13:15 Log Type = 01
Log DA - Health 0000 - HlthDtl 0000 - Time = 00:00:06 Log Type = 01
Log DC - Health 0000 - HlthDtl 0000 - Time = 00:00:06 Log Type = 01
Log D6 - Health 0000 - HlthDtl 0000 - Time = 00:00:05 Log Type = 01
Log D7 - Health 0000 - HlthDtl 0000 - Time = 00:00:10 Log Type = 01
Log D8 - Health 0000 - HlthDtl 0000 - Time = 00:00:10 Log Type = 01
Log D9 - Health 0000 - HlthDtl 0000 - Time = 00:00:09 Log Type = 01
Log DB - Health 0000 - HlthDtl 0000 - Time = 00:00:04 Log Type = 01
Log DD - Health 0000 - HlthDtl 0000 - Time = 00:00:05 Log Type = 01
Log 0B - Health 0000 - HlthDtl 0000 - Time = 00:00:20 Log Type = 01
Log 7C - Health 0000 - HlthDtl 0000 - Time = 00:00:08 Log Type = 01
Log 78 - Health 0000 - HlthDtl 0000 - Time = 00:00:05 Log Type = 01
Log 58 - Health 0000 - HlthDtl 0000 - Time = 00:07:47 Log Type = 01
Log 86 - Health 0000 - HlthDtl 0000 - Time = 00:18:20 Log Type = 01
Log 8F - Health 0000 - HlthDtl 0000 - Time = 00:07:19 Log Type = 01
Log 31 - Health 0000 - HlthDtl 0000 - Time = 02:28:58 Log Type = 02
Log AB - Health 0000 - HlthDtl 0000 - Time = 00:00:03 Log Type = 01
Log 32 - Health 0000 - HlthDtl 0000 - Time = 02:23:54 Log Type = 02
Log 33 - Health 0000 - HlthDtl 0000 - Time = 02:31:29 Log Type = 02
Log 34 - Health 0000 - HlthDtl 0000 - Time = 00:00:02 Log Type = 02
Log 36 - Health 0000 - HlthDtl 0000 - Time = 00:03:21 Log Type = 02
Log A8 - Health 0008 - HlthDtl 0002 - Time = 00:00:38 Log Type = 02
Log 37 - Health 0000 - HlthDtl 0000 - Time = 00:00:55 Log Type = 02
Log 26 - Health 0000 - HlthDtl 0000 - Time = 00:00:11 Log Type = 01
Log 3A - Health 0000 - HlthDtl 0000 - Time = 02:02:14 Log Type = 02
Log 3B - Health 0000 - HlthDtl 0000 - Time = 00:06:06 Log Type = 02
Log 3C - Health 0000 - HlthDtl 0000 - Time = 00:01:01 Log Type = 02
Log 3D - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 02
Log 3E - Health 0000 - HlthDtl 0000 - Time = 00:00:00 Log Type = 02
Log A9 - Health 0000 - HlthDtl 0000 - Time = 00:00:04 Log Type = 01
Log 3F - Health 0000 - HlthDtl 0000 - Time = 00:00:12 Log Type = 01
Log 20 - Health 0000 - HlthDtl 0000 - Time = 00:06:38 Log Type = 01
Log 87 - Health 0000 - HlthDtl 0000 - Time = 00:31:42 Log Type = 01
Log 88 - Health 0000 - HlthDtl 0000 - Time = 00:00:05 Log Type = 01
Log 41 - Health 0000 - HlthDtl 0000 - Time = 00:25:04 Log Type = 01
Log 44 - Health 0000 - HlthDtl 0000 - Time = 00:43:31 Log Type = 01
Log 97 - Health 0000 - HlthDtl 0000 - Time = 00:11:01 Log Type = 01
Log 48 - Health 0000 - HlthDtl 0000 - Time = 00:09:03 Log Type = 01
Log 49 - Health 0000 - HlthDtl 0000 - Time = 00:58:35 Log Type = 01
Log 4B - Health 0000 - HlthDtl 0000 - Time = 00:12:03 Log Type = 01
Log 4D - Health 0000 - HlthDtl 0000 - Time = 00:00:52 Log Type = 01
Log 8B - Health 0000 - HlthDtl 0000 - Time = 00:00:08 Log Type = 01
Log E1 - Health 0000 - HlthDtl 0000 - Time = 00:03:03 Log Type = 01
Log 35 - Health 0000 - HlthDtl 0000 - Time = 00:02:57 Log Type = 01
Log 6F - Health 0000 - HlthDtl 0000 - Time = 00:00:13 Log Type = 01
Total Cert Time = 23:32:19
ASCII logging off
Power Cycling
OkEnd Test 50
T>
T>T4E
T>T4E
Begin Test 4E
Cert Table loaded
ASCII logging on
Not Power Cycling
ASCII logging off
ASCII logging on
ASCII logging off
Power Cycling
OkEnd Test 50
T>
T4E is not good idea on bad drive, if error is encountered during procedure can result in severe damage to CERT code/tables.
Are you able to view any sectors on sector edit after DE start following app modification?
I am not even able to get the drive ID. The drive is still writing the errors in a loop and if I try to read the ID it goes BSY.
I have the same disk and the same terminal output. Has anyone solved this problem?
I'm thinking weak heads / write element failure
I just had a 7200.10 drive which was able to read a little but then gave up. The terminal was also showing some "pending" blocks. New heads resolved the whole problem, only a few bad blocks.
Thank you for advice.
Users browsing this forum: File-Savers and 12 guests
