Need modules for ST3200827A 3.AAE
jerk66
Postby jerk66 » 21.11.09, 15:33
I need modules for ST3200827A 3.AAE.
Anyone can help me. Please
Re: Need modules for ST3200827A 3.AAE
Postby AJ2008 » 23.11.09, 10:21
What do you mean 'modules'? Can you explain the problem you have with your seagate?
jerk66
Postby jerk66 » 23.11.09, 12:54
I have a message on power hdd
Failed sys sect. write
Unable to load overlay 01|000A
I read on the forum that it was the module 01
Ca you help me please.
Postby AJ2008 » 23.11.09, 15:52
For this you need begin a DE task with 'utility actions' option using a LDR, and there is option you can select for 'Fix overlay 01 not laoded'. this will give you data access.
You should be able to reach T> from terminal on this drive, and create a LDR from it.
jerk66
Postby jerk66 » 23.11.09, 16:12
which is the command for create a LDR from it?
Postby AJ2008 » 23.11.09, 16:48
The options you need are in the toolbar of the Seagate Utility. I think the icon that looks like a floppy disk is what you need, but you can check by looking in the manual or holding mouse over button to see its description.
jerk66
Postby jerk66 » 23.11.09, 17:29
Here is the log
Selected family......................... : Barracuda 7200.9 Tonka2
Selected model.......................... : ST3200827A
Model by ID............................. : <HDD ID NOT READ>
Detection of HDD COM port baud rate..... : 9600
Terminal : detecting SA bounds...
SA bounds identified
Test : Saving LDR from HDD
HDD profile file......... : C:\Programmi\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Barracuda 7200.9 Tonka2\qwerty\Data\LDR\SgLDR.ldr
Will be stored........... : ROM, App, CERT code, CERT tables, Ovl 0, Ovl 1, Stuff, DRV cfg
DRV cfg reading...
DRV cfg reading......................... : Ok
STUFF reading...
Detecting Stuff position...
Stuff cylinder.......................... : 0x164EF
Vendor Data start....................... : 0x14
PN...................................... : 100391381
STUFF reading........................... : Ok
CERT code reading...
Trying to load CERT
CERT Rev................................ : .08H
CERT code cyl. index.................... : 0x32
CERT code length........................ : 0x408
Block 0, 0x164E7 : 0x0 : 0x0 (0x280)
$Switch to full int.
AM Reacquired
Detecting next track.................... : Ok
Block 1, 0x164E7 : 0x1 : 0x0 (0x188)
CERT code reading....................... : Ok
CERT tables reading...
Detecting CERT tables position...
Detecting CERT tables position.......... : 0x164E9 : 0x0 : 0x188 (0x18)
CERT tables reading..................... : Ok
Detecting ATA Overlay position...
Err> Terminal : reply timeout error
ATA Overlay (0)......................... : Error
ATA Overlay (1)......................... : Error
Error detecting ATA Overlay position!
Phase : Rebooting
HDD reply :
Postby AJ2008 » 23.11.09, 18:31
You need only save App Code from HDD.
jerk66
Postby jerk66 » 23.11.09, 22:17
I used de but if i want repair hdd, how i can fix overlay.
Please
Postby AJ2008 » 24.11.09, 08:11
I am sure it can be done, but have never tried repairing so cant help sorry.
