ST3320620A - CorrectWriteStart
ZeBong
Postby ZeBong » 18.06.08, 23:05
I have a SEAGATE DRIVE when i connect to the pc3kumda
Reset
4096k x 32 DRAM
GALAXY - 1_Disk S-6D 09-22-06_15:48
HM SFI
(P)PATA Reset
Master
AT Er 00 Nwt Er 43 RdWr 19b8d.00.01ef
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 97f29ff7 b6 97f29ff7.3.640 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 019b8d.00.01ef
CE Log ErrCode=43 LBA=20fb758c Type=5 Add To Pending 20fb758c
AT Er 00 Nwt Er 47 RdWr 19b8d.00.01f0
Niwot: 9ff79ff7 b6 9ff79ff7.3.640 0000 005f 0000 0000
DiskAccess ReadSector EC=47 at 019b8d.00.01f0
CE Log ErrCode=47 LBA=20fb758d Type=5 Add To Pending 20fb758d
AT Er 00 Nwt Er 43 RdWr 19b8d.00.01f8
CE Log ErrCode=43 LBA=20fb7595 Type=4 Remove from Pending 20fb7595
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 19b8d.00.01f2
Niwot: 20fb758e 14 20fb758e.a.610 0008 3642 0008 0000
Spare of 20fb758f failed
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 19b8d.00.01f3
Niwot: 20fb7590 14 20fb7590.a.610 0006 3644 0006 0000
Spare of 20fb7590 failed
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 19b8d.00.01f4
Niwot: 20fb7591 14 20fb7591.a.610 0005 3645 0005 0000
Spare of 20fb7591 failed
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 19b8d.00.01f5
Niwot: 20fb7592 14 20fb7592.a.610 0004 3646 0004 0000
Spare of 20fb7592 failed
CorrectWriteStart
AT Er 00 Nwt Er 1b RdWr 19b8d.00.01f6
Niwot: 20fb7593 14 20fb7593.a.610 0003 3647 0003 0000
Spare of 20fb7593 failed
What is this error?
What can i do for it ?
Jose
Igor
Postby Igor » 19.06.08, 11:32
Hello ZeBong.
This is a common error for this drive. So it could be caused by two reasons:
- dameged PCB
- dameged heads
Check the heads. If they are allright, change the PCB.
ZeBong
Postby ZeBong » 20.06.08, 00:22
Thanks for the Info,
i Change the PCB and change the heads, but the problem still the same error.
I think this is a FW problem, how can i correct this FW problem.
Jose
Igor
Postby Igor » 20.06.08, 10:46
Hello ZeBong,
There is one thing that I want to know.
Is this error appears after drive energization, because if it's so, you could fix
it only with the next update.
If error appear in other way, it can be damaged plate.
Awaiting for reply
ZeBong
Postby ZeBong » 20.06.08, 11:55
Hello Igor,
Yes it appear when the drive give power.
Jose
Igor
Postby Igor » 20.06.08, 11:57
So wait some. Soon you will solve this problem. :)
misa
Postby misa » 23.06.08, 10:42
Hello Igor,
I have the same problem with 2 drive.
Can you give us the delay for that upgrade ?
I need to inform my customer for delay
Misa
Igor
Postby Igor » 24.06.08, 11:36
Hello Misa,
We'll try to do it in 2 or 3 months. Maybe later because I can't give you exact time.
