Seagate ST500DM002
Posted: 06.07.15, 05:48
Hello ,
Having ST500DM002
BSY Status ,
No clicking sound Spinning fine.
Tried ISOLATION and shorting method but not worked.
Changed PCB with writing rom but same issue.
Patient PCB does not go to Terminal mode T3,also donor PCB also not after writing ROM by Terminal. But following log file on terminal
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MediaPartition:
Host LBA Length Disc LBA Length Start Cyl Head
Media Partition 00000000 0099FF00 00000000 00133FE0 00000000 00000000
MC 00000000 0098A018 00000000 00131403 00000000 00000000
MSP 00997840 00000C40 00132F08 00000188 00000688 00000001
User Partition 0099FF00 00133FE0 0000067D 00000001
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 060DBEBC 060DA1A8
Seg Write Preamble VBM start: 00000D3C end: 00000D63
Footer - start: 00000D65 end: 00000D8C
Seg Read Preamble VBM - start: 00000D8E end: 00000DB5
Footer - start: 00000DB7 end: 00000DDE
Nonvolatile MCMT sequence number 01193EBC
[RSRS] 1003 DiscLba 0008C1A4 RW_RTL FFFFFFFF
ProcessRWError -Read- at LBA 0008C1A8 Sense Code=40000087
ProcessRWError -Read- at LBA 0008C239 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0008C239!
[SW] 0002
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Continuing after error
ReadFooters (Forward): Segment 1004 StartLBA 00461180 Starting Footer LBA 004613B0
SeqNum 01193EBE TotalUserBlocks 0200 DiscLba 0008C276 RW_RTL FFFFFFFF
ProcessRWError -Read- at LBA 0008C278 Sense Code=40000087
Footer Status = 0001 DiscLba 0008C27B RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0008C280 RW_RTL FFFFFFFF
ProcessRWError -Read- at LBA 0008C280 Sense Code=40000087
Footer Status = 0001 DiscLba 0008C285 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0008C28A RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0008C28F RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0008C294 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0008C299 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0008C29E RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0008C2A3 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0008C2A8 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0008C2AD RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0008C2B2 RW_RTL FFFFFFFF
Footer Status = 0001 DiscLba 0008C2B7 RW_RTL FFFFFFFF
ProcessRWError -Read- at LBA 0008C2B7 Sense Code=40000087
ProcessRWError -Read- at LBA 0008C2B9 Sense Code=40000087
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch, No Valid Footer 01193EBE 55AA55AA
Reconstruction: ProcessIncompletelyWrittenSegment
Adds LBA/Len
0004FF67/0008 001B40A7/0010 001B7488/0007 0034FDAF/0008 0046C56F/0008 004E387F/0008 006906BF/0008 006B3AEF/0008 0073CCBF/0008 0073F037/0008 0075CF57/0008 007711CF/0008 0077450F/0008 00774697/0008 007A8E9F/0008 007D0DCF/0008 007D166F/0008 007D9DC7/0008 0096B1D7/0008 00C3AA0F/0008 00C3D6B7/0008 00D0781F/0008 00D1C70F/0008 00D236FF/0008 00D385AF/0008 00D494F7/0008 00D516A7/0008 00D9D9FF/0008 00DD2D2F/0008 00DE5E97/0008 00DFE78F/0008 00F32B2F/0008 010835BF/0008 010943B7/0008 0109CB17/0008 0109FDA7/0008 01229737/0008 01233B5F/0008 01239BBF/0008 0123B467/0008 012969A7/0008 012A76B7/0008 012B2D5F/0008 012BA737/0008 012BC3BF/0008 012C1ABF/0008 012D13DF/0008 012DF877/0008 012EC137/0008 012F33CF/0008 013226BF/0008 01330A07/0008 0134F22F/0008 01365D17/0008 0136A7BF/0008 0136BBF7/0008 01381127/0008 0138B337/0008 0138C907/0008 0138EE77/0008 013A9AEF/0008 013ABA17/0008 013AF61F/0008 013AFB17/0001
Add Count 00000040
Rems LBA/Len
Reconstruction: Last Chance DiscLba 0008C2BC RW_RTL FFFFFFFF
Please Guide,Thanks
Having ST500DM002
BSY Status ,
Rst 0x10M
Spin Up
(P) SATA Reset
MediaPartition:
MCMainPOR: Start:
[SW] 0002
Adds LBA/Len
Add Count 00000040
Rems LBA/Len
Please Guide,Thanks
