need help with WD10TMVW USB drive recovery
Posted: 30.12.12, 22:14
I have a newer model 1tb western digital my passport drive with a usb 3.0 connector on the pcb that needs a head replacement from a drop.
My question is after I do the head replacement, what do I need to match up for a serial ata board to do a rom rebuild on the new sata board so I can image this drive? Once I find a compatible pcb do I rebuild the rom from the service area?
The model of the drive is
WD10TMVW-11ZSMS5
DCM: EHMTJBBB
DCX: HZ5CS3RMR
PCB information on original USB PCB is 2060-771814-001 Rev P1
I found a donor drive with the first 5 digits of the DCM match, but what do I need to match for a compatible PCB? I can’t find a sata board that matches that 2060-77184-001 number.
WD10TMVW-11ZSMS5
DCM: EHMTJBBB
DCX: HZ5CS3RMR
