Another bug? Viewing WD modules from Module Directory
Posted: 11.07.12, 02:09
In module directory, right click module and "view module" (or double click to view module) --> works the first time. Then every other module I try to "view" returns the same sector data from the first module. Only work-around is to close module directory, reopen, and view different module. Need to close/reopen every time I want to view another module.
So far this problem has occurred with WD20EARS-00MVWB0 (sadle G6) and now for testing also with WD30EZRS-00J99B0 (dragon) and WD15EARS-60MVWB0 sadle G6). In fact, I can't get it to NOT happen with WD drives.
Could someone else please check with a similar (or ideally same) model drive to find out if it's just me or a real bug?
