sn3964 wd5000BMVW-11AMCS0 usb ATA command err method 3
Posted: 08.12.11, 05:42
by drdoc
This is a usb 3 drive.
Connected with usb 2 cable
windows see drive.
start pc3000
select WD USB models
pc3000 see drive and model #
try autodetect
drives light flashes
then gets errorL
hdds ram reading error; unexpected error: ATA command sending error (method 3) win32 error. Code 121
The semaphore timeout period has expired.
Now if you reenter the utility it cant find the usb drive.
Windows can still see and access the drive but it gets errors and locks up.
Re: sn3964 wd5000BMVW-11AMCS0 usb ATA command err method 3
Posted: 14.12.11, 12:33
by dmarques
You're not very clear in your explanation.
What do you mean Windows sees the drive?
Posted: 14.12.11, 19:09
by drdoc
windows sees a 500gb drive attached.
it detects it in compter management->disk-management
The drive is wd encrypted.
ts got a gpt pasrtition
so its probably mac
it gets hung up w bad sectors starting at 4.9 million.
maybe I just need to clone it...
but the pc3k isnt talking to it...
Posted: 15.12.11, 11:52
by dmarques
Can you post a screenshoot of the errors please?
Posted: 24.12.11, 00:16
by drdoc
Model : WDC WD5000BMVW-11AMCS0
Serial : WD-WXE1A61N3964
Firmware : 01.01A01
Capacity : 465.76 GB (976 773 168)
I finally figured out the pinouts for the terminal connection.
It starts up with this below.
But I cant seem to be able to do anything else.
What are the instrucitons for talking to these usb drives.
Do you turn the power on the pc3000 card or not?
Kernel mode?
Autodetect?
Ok
I got it to read the modules.
The only thing I did different is to power the usb from an external ps and not from the motherboards usb.
I also did not power on the pc3k card.
Its backing up resources now..
Techno mode key
SA SPT.................................. : 1098
ROM version............................. : 10.0UA
ROM generation.......................... : 10.0UA
Link table version...................... : 02.13.
Consolidated ROM version................ : 0010000U
ROM Modules:
ROM Firmware version.................... : 0010000U
Service area:
SA dir reading.......................... : Ok
