Modules needed for HTS545025B9SA02
Posted: 18.11.10, 15:55
by Francois
Modules needed for HTS545025B9SA02(Ram0)
Re: Modules needed for HTS545025B9SA02
Posted: 18.11.10, 16:16
by dmarques
Do you have all copies damaged?
Can't you rebuild one good module from areas from 3 copies?
Posted: 29.11.10, 17:16
by Francois
All three copies are damaged.
As for combining the good areas of three bad modules. I've never done that.
Any guidance would be appreciated.
Posted: 30.11.10, 09:36
by dmarques
You can use the option View Service Information Objects, then read the damaged module with the option Ignore Reading Error. In the end you'll see what was possible to read from the module.
Do that for all 3 copies and then check which areas are damaged in the copies.
But by the way, have you tried to write something to SA to check if heads can write?
