Problem with PC3000 after software update
Posted: 08.11.10, 06:53
Since I upgraded to the latest PC3000 software release, one of our PC3Ks is acting strange and really annoying.
When working with Data Extractor, the power to the patient drive will shut off with odd and unpredictable trigger events. Sometimes just stopping the imaging process will cause the power switch icon to open up. Other times, power dies when the imaging process encounters a difficult or bad sector, even when the unit is programmed to do a soft reset only (no hardware reset as with smart hot swap). I can't identify a single event that causes the problem in any repeatable fashion.
It really ruins productivity and reliability.
Sometimes when we exit the utility, it will default to showing power on ATA1. We only use channel 0, and the defaults are set to this. We have to then select ATA0 to manually turn off power to the drive.
Is anyone else having similar issues? I'm afraid to install the upgrade to the second PC3000 in case it is a software bug.
Thanks in advance,
Balvan
Thanks in advance,
Balvan
