LCD turns off while "Search for NTFS structure" performing
Posted: 26.04.10, 09:58
Hello friends,
According to the fact, that this is my first post on this forum. I would like to introduce myself.
My name is Robert (from Poland) and want to learn a lot about data recovery sector, hope together we will be able to find optimal solutions in our daily problems with HDD's.
A few days ago, I was instructed by Roustam to run "Search for NTFS structure" on the WD HDD (320GB ATA) which I want to recover two ZIP files from.
(By the way Recuva and R-Studio have found this 2 ZIP files but its size is "zero bytes" does it mean these files are lost forever or maybe is there a chance to recover it with PC-3000 UDMA and Data Extractor ? )
Let's back to the current problem. Below You will find steps which I have performed:
- I connected the cables to HDD
- I run PC-3000 UDMA with admin rights on my Windows 7 system
- I powered on the HDD, indicators on the bottom are DRD and DSC.
- I opened Data Extractor and selected New Task
- As source I indicated PC3000 ATA 0 channel - because the drive there is connected
- Next window is "Task initialization" I left all options as default (software reset, hardware rest, read drive ID, 25000ms)
- Next windows is "Task options" I left all options as default (nothing is checked)
- Next small window appeared "Parameters" I left all options as default, and pressed OK
- After that step the utility started to run and after a few seconds my LCD became black with a "NO SIGNAL" message.
Momentally I thought my new 19" ASUS LCD is broken, but it isn't.
My ASUS mainboard has got built-in graphic card (on-board) and it also works. I switched my power supply off, turned it on again and my computer started normally as usual.
Then I connected another disk Seagate 500GB (HD502HJ) and the same problem occured while performing "Search for NTFS structure" !!!
I have no idea what's wrong, waiting for Your help friends.
Thank You in advance
Best regards,
Robert
Best regards,
Robert
