Need Any NVR for HDS721680PLA380
Posted: 20.05.09, 11:20
by Powermax
I need NVR (the version is not imnportant) for HDS721680PLA380
Someone have it please ?
Thank You
Re: Need Any NVR for HDS721680PLA380
Posted: 28.05.09, 17:01
by ACE_Admin
Very probably you could recover the NV-Ram from SA. Please try to use donor's board and launch "Nv-ram adjustment" command with default values.
See my screenshot attached.
- recover_nvram.JPG (42.08 KiB) Viewed 3732 times
Posted: 29.05.09, 12:26
by steven
Do u sure your PCB is not the original PCB..
if not try to restore NVR from SA Copy. there is the only option.
if you found other NVR. i dont think it will help u..
I have some of this NVR if you want i can send to you
Posted: 29.05.09, 12:34
by Powermax
No tanks. i solved problem to read NVR from SA. Thank you the same. Bye
