sn 8588 WDC WD20EARS-00MVWB0, stays uo, accepts loader
drdoc
Postby drdoc » 08.12.11, 05:17
This drive acts like it comes ready,
says spun up but enters kernel mode.
editting head map to 0's or 1's gives same result.
did accept a loader but got an error...
Now what ?
Techno mode key
ROM version............................. : 50.77B
ROM generation.......................... : 50.77B
Link table version...................... : 0A.21.
Consolidated ROM version................ : 00500077
ROM Modules:
Heads map............................... : 0,1,2,5,6,7
ROM Firmware version.................... : 00500077
View ROM information
Firmware version........................ : 00500077
ROM Modules
0A : Heads map
0B : Flash ROM dir
30 : SA Translator
47 : SA Adaptives
0D : Flash configuration
4F : Microprogram version
5A :
5B :
SA Regions
N : ABA : Size
0 : 0 : 380 160
1 : 506 880 : 380 160
2 : 1 013 760 : 380 160
3 : 1 520 640 : 380 160
4 : 2 027 520 : 380 160
5 : 2 534 400 : 380 160
Micro Jogs
LH : PH : Micro Jog (Hex/Dec)
0 : 0 : CD8/3288
1 : 1 : D50/3408
2 : 2 : CCD/3277
3 : 5 : D2A/3370
4 : 6 : CE5/3301
5 : 7 : D1C/3356
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< try herad map edit
000000 or 111111 acts the same - kernel mode.
got it to take a loader and it says this after getting DRD DSC ERR ABR
Model : WDC WD20EARS-00MVWB0
Serial : WDC-ROM SN# XYZ----
Firmware : 51.0AB51
Capacity : 310.88 GB (651 969 361)
LDR Data uploading...................... : Ok
Techno mode key
ROM Modules:
Flash ROM dir reading................... : Module ID 0B reading error Data request error - Device Error Detected: "Unknown error. Error code: 0101"
Heads configuration..................... : default
Heads map............................... : default
ROM Firmware version.................... : Module ID 0B reading error Data request error - Device Error Detected: "VSCE VSC MODE DISABLED"
Service area:
SA dir reading.......................... : Device error detected VSCE VSC MODE DISABLED
dmarques
Re: sn 8588 WDC WD20EARS-00MVWB0, stays uo, accepts loader
Postby dmarques » 14.12.11, 12:06
Is that a Sadle family drive?
I found that those ones often come ready, but H0 is damaged, preventing them from reading correctly.
