Is it possible to clone an iMac drive without opening and removing drive(s)?
Posted: 12.10.17, 06:39
I've run into the situation a few times where I have received a modern iMac (which needs to be cut open and is a - to extract the drive from, and put back together and reseal, (especially if there is a fusion drive)).
I have a case now where the client had an employee leave, and they want to see the employee's documents and what they were up to etc, as they suspect potential foul play.
The iMac is working normally and there is no reason to suspect the drive is bad, so I really want to try to clone the drive and then deep scan for deleted files / RAW recoverable data.
I suppose if I could boot from a USB boot drive with Data Rescue or Rstudio, I could just use the boot drive and scan it directly from that and export the results to an external drive.
Currently, I've put the iMac into target mode and connected via thunderbolt to a mac mini.
I've been able to run an old version of carbon copy cloner, from when it still had 'block copy'. Apparently, the new versions no longer have 'block copy'. Still, I'm not sure if 'block copy' in CCC is actually a sector-sector clone.... It completed in a reasonable amount of time (under 6 hours).
Alternately, I've tried to scan the iMac in target mode with Data Rescue 4 (on the mac mini), but it's going to take 4-14 days at the speed it's scanning to scan just a 1TB drive.
I've tried unsuccessfully to create a working bootwell drive with DR4... the usb bootwell drive gets created, but just doesn't work to boot any systems.
Anyone have suggestions for this situation? Do you think I just need to bite the bullet and remove the drive?
The customer's budget doesn't allow for a true 'forensic' case... They just want the ex-employee's old data, Including any deleted data to be recovered.
