Hardware configuration used for PC3000
Posted: 21.05.10, 03:27
Hi all,
I want to ask You a question related to Your hardware configuration which is combatible with PC3000 UDMA.
My current configuration is listed below and I can say that I've got some kind of hardware problem, because while performing "search NTFS structures" in DE, my PC freezes and the only thing to use is power off button.
My system configuration is:
Motherboard: ASUS M4A785TD-V EVO - chipset AMD 785G
CPU: AMD Athlon II x4 620 s.AM3
RAM: Geil 2x2GB DDR3 1333 Dual Chanel Kit 9-9-9
PSU: OCZ StealthXStream OCZ500SXS-EU 500W
HDD: Samsung 500GB 16MB HD502HJ F3 sATA-2
OS: Windows 7 Professional x86 (32bit)
I was testing all devices separately and everything works fine, I also installed XP on the configuration above and the problem still exists. The curious thing is that on my old computer (Athlon XP 1800+ and ECS Motherboard with XP operating system) everything works fine.
I want to ask, what kind of motherboard and CPU are You using ? to determine if shall I buy rather motherboard for AMD or Intel.
Maybe the chipset 785G is making the problems ?
Waiting for Your comments, thank You.
