Accorrding to Aclab conferent at Dubrovnik 2025 when you ask users to share some ideas to improve the PC3K tools, I propose make some kind of "wish list" topic.
The main goal is to share some good ideas, which can be implemented to software and make life more easier for everyone (except the developers, which need implement this ideas
I think it would be good split ideas to different topics:
1. PC3000 Express / Portable
2. Data Extractor
3. PC3000 Flash
This topic would aim to implement good and feasible ideas. And not unreal.
To begin with, I suggest:
PC3000 Flash:
- add possibility manually choose ECC from the list for current case. Why? When dump quality is not so good, software try find it with very long time or even't can't find it at all. Without ECC we can't use RR, so we can't move forward.
Data Extractor:
- add possibility to jump to next chunk/file on map when reading is very slow at some areas. Option should have possibility skip file when reading is like 1 sector per one second. It would be good if we can set sectors quantity and timing here.
PC3000 Express / Portable:
- sometimes for some SSD we can't rebuild translator due to bad chip quality or other issue, but we can look on dumps sectors by sectors, but can't save whole dump (some utility offer it, but not all). If we can save full dumps with SA area trough the controller with removed encryption and ECC calulated by controller we can try assembly data as standard flash case.
