VCC or other voltage on monolith modul
Posted: 01.10.17, 16:23
by jerema
what is the difference between: VEXT, VCC, V2, 5V, 3,3V on the monolith modul?
Thanks for information
Re: VCC or other voltage on monolith modul
Posted: 02.10.17, 10:07
by Roman_TS
VEXT - pin for external power supply connection,
VCC - power supply in case is extended power supply source is connected.
V2 - power supply from PC-3000 Flash reader;
5V - power supply for UISB monolith;
3.3V - changeable power supply for all others monolith chips.
More info you can read there:
http://blog.acelab.eu.com/pc-3000-f ... tures.html
Posted: 03.10.17, 12:12
by jerema
Thanks, but where I have to solder:
VCCQ
VSP1
VSP2
VCC
VSSQ
Posted: 03.10.17, 16:39
by Roman_TS
Can you show me pinout that you are going to solder to Circuit Board?
Posted: 03.10.17, 22:52
by jerema
Hello Roman,
I want to solder an adapter to use other adpaters on PC3000.
Posted: 04.10.17, 09:06
by Roman_TS
I don't know what is VSP1 and VSP2, but VCCq - is a GND for VCC (power supply of NAND core), and VSSq - GND for VSS (power supply for buffers). VCC and VSS need to solder on V2, and VSSq/VCCq - on any of GND.
Posted: 04.10.17, 20:30
by jerema
Thanks a lot Roman.
I will try it.
Posted: 13.10.17, 20:34
by jerema
Hello Roman,
I can not find WP on Monolith model.
Is this neccesary ?
Posted: 14.10.17, 17:46
by Roman_TS
Hello!
WP is not necessary, because it's Write Protect. This pin might be ignored, or soldered like a GND. I prefer to skip it at all :)
Posted: 15.10.17, 09:36
by jerema
OK :thumbup:
