SanDisk Ultra Fit weird usb monolith
Posted: 03.10.23, 21:43
Ill start by saying that opening this is a nightmare. Its molded plastic contact to backing. This is a tester drive not the patient. cracked in disassembly but just seeing if it is even worth my time to try. I believe it is encrypted by the white dot on the front of the nand. masking is a nightmare to remove.
Model on the device is SDCZ430-064G
Label on Nand is 3282ZEU74037 064G WHITE dot top left
Will not recognize, shows RAW, ALL 0's in sectors.
A small resistor is to one side and it uses usb 3.1 protocol with the leads for usb. 4 on one side and 3 on the other side.
Corrected: (not chip off)
Big question is a monolithic recovery even possible? cant find it in database.
thanks for any insights. haven't struck out in a while, figure id throw it up here just in case one of you went down this road and lost a day of life. haha.
