pin out
Posted: 29.04.19, 14:40
by codice pin
I can't find the points of this samsung 32gb
Re: pin out
Posted: 30.04.19, 23:22
by Roman_TS
We have this pinout, but recovery of this mSD is impossible due the adaptive XOR. Even if you will read it, complete recovery will be impossible.
Re: pin out
Posted: 02.05.19, 17:31
by codice pin
can I have it? I want to do cross-tests with other tools
Re: pin out
Posted: 02.05.19, 21:12
by Roman_TS
Nobody can beat this adaptive XOR, even other tools ;) But you can PM me, I will reply you in next Monday.
Re: pin out
Posted: 03.05.19, 15:57
by Multi-COM
@codice pin: Those Samsung cards uses a cipher with a rotating key which is based on LBA so as Roman write you will not recover data from it unless you will get correct key from Samsung.
Re: pin out
Posted: 06.05.19, 17:38
by codice pin
I trust what you tell me, I still wanted to dump and try, but I can't find the right points and apparently nobody has them
Re: pin out
Posted: 12.09.19, 10:11
by Paulsen
I got a Sony mSD with the same layout. Do you know if they also use an adaptive XOR, or could a recovery be possible?
