I am working on a USB flash drive with a NAND package that has 48 physical pins (24 per side), but the package is significantly wider than a standard TSOP48 and does not fit the normal TSOP48 socket.
I therefore soldered the NAND on the PC-3000 Flash LGA52/TSOP48 replaceable module.
The problem is that PC-3000 immediately reports:
PWR ON Error on channel VCC – Overcurrent detected
I first suspected the orientation, because the package marking / pin 1 indication does not seem to match the triangle/reference on the module.
I tested the chip in both possible orientations, but I get VCC Overcurrent in both cases.
The NAND has exactly 48 visible leads, but because of its unusual width I am not sure whether this is:
a TSOP48 Wide package,
a special TSOP56-derived package with some missing leads,
or another non-standard NAND pinout.
I have attached photos of:
the NAND soldered on the LGA52/TSOP48 module;
the original USB PCB with the NAND removed;
the original NAND footprint;
the current jumper/wiring configuration on the PC-3000 module.
Before trying anything else and risking damage to the NAND, could you please advise:
What package/pinout is this NAND likely to use?
Is the standard LGA52/TSOP48 module suitable for this chip?
Does this type of NAND require a specific VCC/V2/VCCQ jumper configuration?
Which orientation should be used on the module?
Is there a specific PC-3000 Flash adapter or wiring diagram for this type of wide 48-lead NAND?
Any advice would be greatly appreciated.
Thank you.
48-pin wide NAND on LGA52/TSOP48 module – VCC Overcurrent in both orientations
- italyassistance
- New user
- Attachments
Re: 48-pin wide NAND on LGA52/TSOP48 module – VCC Overcurrent in both orientations
It will be very tricky to solder it correctly due to the unknown power scheme for this chip. Some NC contacts may use for VCC or VCCq, and it's not easy to find out the correct scheme.
Instead, we recommend to upgrade your reader by cutting some plastic borders on TSOP-48 adapter. After that, you will be able to read both of TSOP48, including TSOP48W.
- italyassistance
- New user
Roman_TS wrote:Source of the post Hello,
Can you confirm that this specific 48-lead wide NAND uses the standard TSOP48 pinout and standard VCC/VSS positions? Could a different VCC/VCCQ power scheme cause immediate VCC Overcurrent when using the modified standard TSOP48 socket?
It could use a non-default power supply scheme. Try to modify your adapter and check.
- italyassistance
- New user
Roman_TS wrote:Source of the post It could use a non-default power supply scheme. Try to modify your adapter and check.
hi roman i modified adaptor chip enter perfectly, but all times chip go in overcurrent
That's not all you need to do:
1. Follow by Main PC-3000 Windows - Options - PC-3000 Flash parameters - BGA-152 adapter - and select the checkbox Modified Adapter.
2. To read this chip you should set VCC on 2,45 and VCCq on 1.8V during chip ID reading.
- italyassistance
- New user
Roman_TS wrote:Source of the post That's not all you need to do:
it doesn't let you choose adapter 152 there is only 48
Indeed
I was working with another BGA-152 case and missed a bit with correct answer.
Please make a ticket, me or other engineers will guide you regarding this TSOP-48 reading.
- italyassistance
- New user
i think that this monolith is out, i try all voltage but chip is always in overcurrent
