Sandisk Extreme 128GB LDPC?
datahelp
Postby datahelp » 15.04.24, 11:04
Hello, does anybody know if this SD card use LDPC ? I don't have pinout for this so I wonder if it's worth to find the correct one.
Thank you
datahelp
Re: Sandisk Extreme 128GB LDPC?
Postby datahelp » 15.04.24, 13:04
Solved. It's LDPC.
Chetan1207
Postby Chetan1207 » 29.04.24, 09:18
Hi Datahelp,
What was the problem you were facing with this ?
datahelp
Postby datahelp » 23.05.24, 15:20
Hi, this card uses LDPC algorithm + probably encryptioin, so there is no way at this moment to solve it.
Chetan1207
Postby Chetan1207 » 04.06.24, 16:31
Hi, Thanks for the reply
Ok, I get it but you mentioned that you have solved this case. So I was asking what problem were you facing??
datahelp
Postby datahelp » 11.06.24, 13:35
Sorry, I mean the problem was "solved" (not the case), because it's imposible to recover this card.
