Sony/Sandisk 160GiG
Moderators: Alex_TS, Roman_TS, Filipp_TS
Dataman
Sony/Sandisk 160GiG
Postby Dataman » 11.05.22, 17:50
Anybody ever work on one.
S
Re: Sony/Sandisk 160GiG
Postby Roman_TS » 12.05.22, 09:08
It's a Sony CFast card. Works like a small SSD, with a complete SSD controller inside. Chip off will not help here - everything will be encrypted by the internal CPU.
At the same time, as I can see, the current drive has a problem with the internal translator inside the FW. Drive shows a wrong capacity and passport details, which means that current SSD stays in Kernel mode because it can not upload the firmware.
blog.acelaboratory.com
Dataman
Postby Dataman » 17.05.22, 17:51
Problem solved
thank you
