One Samsung chip read as 2 chip
Typical Flash recovery cases
hfelemban
Postby hfelemban » 07.10.17, 17:52
I have Samsung K9BCG08U1A-MCB0
Controller SM3255Q
When I read the chip, I found the chip details all, but under the chip threr is 2 chips.
I check all solution no one has 2 chips. The 2 chips are exaclly the same.
It is one chip but in Transformation Graph threr are 2
Should I romve the extra chip?
jerema
Re: One Samsung chip read as 2 chip
Postby jerema » 08.10.17, 21:35
You mean one chip with two parts ?
I think this is correct.
Postby Roman_TS » 09.10.17, 10:03
It's a normal situation when inside one physical chip you can find two logical parts. It's just a way of increasing capacity inside one NAND flash package.
