Which adapter to use, TLGA-52?
Posted: 20.08.16, 20:38
by oldman
I have a NAND chip from a SKhynix,
H2JTFG8YD1BMS
BC A0 441A
Photo attached.
Which adapter to use?
TLGA-52?
Thanks.
Phil
Re: Which adapter to use, TLGA-52?
Posted: 22.08.16, 09:04
by Roman_TS
Hello!
This is TLGA-60 - it has 8 addition pins in central raw. You can try to read it with TLGA-52, but there might be issues.
Posted: 12.03.18, 14:16
by Jaime
Hello Oldman,
I have the same problem,
I need to read the Nand chip H2JTFG8YD3MBR, this is too TLGA-60.
Could you to read the chip with apdapter TLGA-52?
Thank and regards.
Posted: 13.03.18, 11:13
by Roman_TS
For reading BGA-60 with TLGA-52 adapter, you have to chose reading scheme number 1785, and ignore all others during chip reading. It will help.
Posted: 23.03.18, 17:25
by Amarbir[CDR-Labs]
Roman_TS wrote:Source of the post For reading BGA-60 with TLGA-52 adapter, you have to chose reading scheme number 1785, and ignore all others during chip reading. It will help.
if i was at his place i will hardwire the chip to a monolith board :mrgreen:
Posted: 23.03.18, 17:29
I have never had success reading in TLGA-52 reader, but I only see this a small number of times so is not a problem to wire manually for reading
Posted: 23.03.18, 18:11
by oldman
Sorry for the delay as it is such old post, seem that I was not able to read and recover it successfully. :cry:
Posted: 24.03.18, 09:49
by Jaime
I can not read it,
what is the pinout of the chip, to try to read the chip
