Kingston Data Travel 16gb recovery
Posted: 01.12.15, 15:31
by FranZ74_DR
I have a problem with Kingston 8gb flash case recovery. Controller name SSS6698, two chips 0x98DE9892 8gb each. I would like to recover folder structure - is it possible? I perform XOR, page transformation, mix, get a lot of good data in RAW, but I want to build image. How can I do that?
Similar solution:
http://www.pc-3000flash.com/solbase/sol ... 5&lang=eng
Re: Kingston Data Travel 16gb recovery
Posted: 01.12.15, 16:23
by Nick_TS
There is no marker in service area so it's impossible to recover data by block number.
Also there is translator but it's encrypted so we can't recover via translator too.
I see raw recovery only.
Have a nice day.
Posted: 01.12.15, 17:05
by FranZ74_DR
That's a pity. Are you guys have a plan to add translator in PC3K Flash for this controller? Those chips appears several years ago, and customer who gave this UFD to me bought it in 2013!
Posted: 02.12.15, 10:11
by Roman_TS
Hi! We have a problem with current translator. Unfortunately it really very wired, maybe later this algorithm will appear in our software, but for now, the only way to get access to user data - RAW Recovery :(
As I remember, current family of controllers - SSS6696, SSS6697, SSS6698 - the only controllers which have problem with image building...
Posted: 03.12.15, 08:26
by FranZ74_DR
ok, got it, thanks
Posted: 30.04.16, 09:54
FranZ74_DR wrote:Source of the post I have a problem with Kingston 8gb flash case recovery. Controller name SSS6698, two chips 0x98DE9892 8gb each. I would like to recover folder structure - is it possible? I perform XOR, page transformation, mix, get a lot of good data in RAW, but I want to build image. How can I do that?
Similar solution:
Hello Sir ,
Can You Share The Image of This Case "Real Photo " . Have To Seen Other Tools Working Properly With This Controller And The Controller Roman Sir Was Referring to
