Can I add new XORs?
Posted: 18.06.19, 02:02
Hi there.
I have a problem with XOR detection.
The controller is SM3276L.
The memory chip has two parts, $89A46432 - AA010000 6WB2D_NW817 [SDR][Page: 18592 bytes(32 sectors).Block Size: 32768 sectors(1024 pages)] (x8)
Memory size is 64GB.
ECC detection is follows:
>>>>>>>>>>>>>>>>>>>>>>>>Detect ECC for PAGE = 18427 bytes
- 0 [1150]
- 1150 [1150]
- 2300 [1150]
- 3450 [1150]
- 4600 [1150]
- 5750 [1150]
- 6900 [1150]
- 8050 [1150]
- 9200 [1150]
- 10350 [1150]
- 11500 [1150]
- 12650 [1150]
- 13800 [1150]
- 14950 [1150]
- 16100 [1150]
- 17250 [1150]
- 18400 [27]
And XOR analysis detection is follows:
[18.06.2019 09:29:19]: XOR determination...........................
[18.06.2019 09:29:21]: Method will be started on result ID=573
[18.06.2019 09:29:22]: Build XOR list for analisys
[18.06.2019 09:29:22]: Select XOR by ECC format... ECC ID= 1930 18432;16-1150;27;
[18.06.2019 09:29:22]: Result XOR list:
[18.06.2019 09:29:22]: 0) ID=1931 : SM3267 BLK=256 PG=18432 (1150x16+27) 7F6090+ Block Convert Eq+ Page Convert
[18.06.2019 09:29:22]: 1) ID=2090 : SM3267L BLK=258 PG=18432 (1150x16+27SA) -> Skipped!!
[18.06.2019 09:29:22]: 2) ID=2184 : SM3267 BLK=128 PG=18592 (1150x16+27) PL2-3+ Block Convert Eq
[18.06.2019 09:29:22]: 3) ID=2183 : SM3267 BLK=128 PG=18592 (1150x16+27) PL0-1+ Block Convert Eq
[18.06.2019 09:29:22]: 4) ID=2249 : SM2703 BLK=1024 PG=18592 (1150x16+31)_D7AF47
[18.06.2019 09:29:22]: 5) ID=2307 : SM3267 BLK=256 PG=18592 (1150x16+31) D7AF47+ Block Convert Eq
[18.06.2019 09:29:22]: 6) ID=2397 : SM3268 BLK=384 PG=18432(1150x16+27) -> Skipped!!
[18.06.2019 09:29:22]: 7) ID=2415 : SM3268 BLK=2304 PG=18592 (1150x16+27) E8018F+ Block Convert Low
ID=2481 : FROM XOR ID=2415 BLK=2304 PG=18592
[18.06.2019 09:29:22]: XOR number to research:: 8
[18.06.2019 09:29:23]: --------------------------------------------
[18.06.2019 09:29:23]: XOR ID=2249 File Weight: 998 Other Weight: 217743 - Files( 1)
[18.06.2019 09:29:23]: XOR ID= 0 File Weight: 0 Other Weight: 48649 - Files( 0)
[18.06.2019 09:29:23]: XOR ID=2183 File Weight: 0 Other Weight: 29681 - Files( 0)
[18.06.2019 09:29:23]: XOR ID=2184 File Weight: 0 Other Weight: 19948 - Files( 0)
[18.06.2019 09:29:23]: XOR ID=2307 File Weight: 0 Other Weight: 4442581 - Files( 0)
[18.06.2019 09:29:23]: The most probable XOR : 2249
[18.06.2019 09:29:23]: .Confirmed!Removing...
[18.06.2019 09:29:26]: No found any page format for XOR ID= 2249 OK!
[18.06.2019 09:29:26]: Duration : 00:00:07
[18.06.2019 09:29:26]: The results are placed into the group Preparation results". IDs: "757,758
I select Page transformation:
Page size 18592
Sector size 543
Structure
0-512;18400-31;
512-512;18400-31;
1150-512;18400-31;
1662-512;18400-31;
2300-512;18400-31;
2812-512;18400-31;
3450-512;18400-31;
3962-512;18400-31;
4600-512;18400-31;
5112-512;18400-31;
5750-512;18400-31;
6262-512;18400-31;
6900-512;18400-31;
7412-512;18400-31;
8050-512;18400-31;
8562-512;18400-31;
9200-512;18400-31;
9712-512;18400-31;
10350-512;18400-31;
10862-512;18400-31;
11500-512;18400-31;
12012-512;18400-31;
And
Split by block(Block size:32768)
Join by Blocks/Pages for pairs(Block size:32)
Join by Blocks/Pages for pairs(Block size:64)
RawRecovery found many file headers but almost corrupted.
I think XOR 2249 is not match.
Can I add new XORs in the Resource?
- 0 [1150]
- 1150 [1150]
- 2300 [1150]
- 3450 [1150]
- 4600 [1150]
- 5750 [1150]
- 6900 [1150]
- 8050 [1150]
- 9200 [1150]
- 10350 [1150]
- 11500 [1150]
- 12650 [1150]
- 13800 [1150]
- 14950 [1150]
- 16100 [1150]
- 17250 [1150]
- 18400 [27]
Page size 18592
Sector size 543
Structure
0-512;18400-31;
512-512;18400-31;
1150-512;18400-31;
1662-512;18400-31;
2300-512;18400-31;
2812-512;18400-31;
3450-512;18400-31;
3962-512;18400-31;
4600-512;18400-31;
5112-512;18400-31;
5750-512;18400-31;
6262-512;18400-31;
6900-512;18400-31;
7412-512;18400-31;
8050-512;18400-31;
8562-512;18400-31;
9200-512;18400-31;
9712-512;18400-31;
10350-512;18400-31;
10862-512;18400-31;
11500-512;18400-31;
12012-512;18400-31;
And
