Hama SD card 128GB (SM2703) - Dump filled with FF
Typical Flash recovery cases
datahelp
Postby datahelp » 20.05.24, 13:53
Hello I'm trying to read BGA152 memory chip from this SD card. It shows ID 0x2CA45E53C. It has 4 parts, part 0+1 contains data but part 2+3 is completely filled with FF.
Does it mean that memory chip is damaged? Or is it possible to read it different way? For example changing voltage etc.
Thank you
SGdata
Re: Hama SD card 128GB (SM2703) - Dump filled with FF
Postby SGdata » 20.05.24, 14:14
Might be that data is only in first parts and it's joined by dump. Hard to say without seeing it.
datahelp
Postby datahelp » 20.05.24, 15:22
Should I upload some screenshot or more information?
SGdata
Postby SGdata » 20.05.24, 16:02
Shure, or ask support to check it remotely.
