Verbatim 16GB [8+8] CF Phison PS3016-P8-D Help
Typical Flash recovery cases
Postby Amarbir[CDR-Labs] » 10.10.16, 21:03
Hello Roman ,
I Have Tried My Best In Short Limited Period To Crack This Case But i Am Stuck As I Am a Newbie.Please Find The Details
1 : Controller : Phison PS3016-P8-D UT1318A " Is The Second Line Important It Says UT1318A As Stated "
2 : Physical Memory : 2 Units 8GB Each 1 Crystal Each
3 :Memory ID Etc : $2C88044B MT29F64G08CBAAA
Read ID ,Read Chip Done ECC ,Now Stuck ,I Wonder how you folks start and finish the case after these steps .I Think i need to apply XOR and need to do a few steps .Also i Get This Error "Network is unreachable (Error #10051) "Even Though i am connected to Net
Re: Verbatim 16GB [8+8] CF Phison PS3016-P8-D Help
Postby Roman_TS » 17.10.16, 16:15
Amarbir, with such questions better to go in ts.acelab.eu.com
Here on forum we are not provide full TS.
Postby Amarbir[CDR-Labs] » 08.11.16, 13:53
Roman_TS wrote:Source of the post Amarbir, with such questions better to go in ts.acelab.eu.com
Roman ,
The New Tool has Arrived .The Destruction Video Was Uploaded ,New PC 3000 Flash Ver 4.0 is Up And Running ,Will Create a Ticket Right Away
Postby DataMedics » 05.02.18, 16:12
Amarbir[CDR-Labs] wrote:Source of the post
Roman ,
Hey Amarbir, did you get a solution for this Error #10051? I just got my PC-3000 flash and am getting the same error when I try to do the update.
Postby DataMedics » 05.02.18, 18:00
Nevermind, I figured it out. Just had to put my local IP address into the connection settings menu.
Postby Amarbir[CDR-Labs] » 05.02.18, 18:52
DataMedics wrote:Source of the post Nevermind, I figured it out. Just had to put my local IP address into the connection settings menu.
Well,
Glad You Got The PC3K Flash ,This will help you solve many many cases that you were unable to do with that tool you had :mrgreen:
Postby DataMedics » 05.02.18, 20:46
Amarbir[CDR-Labs] wrote:Source of the post This will help you solve many many cases that you were unable to do with that tool you had
"Had" being the operative word here. My VNR has been stuck in Poland customs for 3 months now after I had to send it back for a repair under the warranty. Rusolut is refusing to do anything, not even call customs and try to speak some Polish to them to figure out what's going on. I'm wishing I'd just bought Ace's tool in the first place.
