Samsung SD card
Typical Flash recovery cases
jnicanor
Samsung SD card
Postby jnicanor » 03.08.16, 20:18
Hello there,
I am trying to retrieve the data from a Samsung SD card, this is its data:
Capacity: 8GB
Controller marking: MMB3R08GUACA-GE
Chip ID is detected as ECDED9CA
I make the dump, but then I am having the problem that it does not find ECC even after attempting XOR. I run XOR analysis and detects the mos suitable one as 252.
Have you analyzed similar memory?
Re: Samsung SD card
Postby Roman_TS » 04.08.16, 01:02
Hello. Please, follow to our TS portal and create a ticket. Our engineers will guide you with this case.
jnicanor
Re: Samsung SD card
Postby jnicanor » 04.08.16, 19:39
Thanks for your reply, do I use the same login as the forum/blog? Or do I need to register for that site separately?
Nevermind, I was able to login now :-)
