How to add the xor?
Posted: 21.12.17, 16:31
by Jaime
Hi.
How can I add a xor of a solution
I do not have this xor
example
http://www.pc-3000flash.com/solbase/sol ... 7&lang=enghow to add the xor Page XOR (ID_XOR 2109 ?
Thank yoy
Re: How to add the xor?
Posted: 21.12.17, 17:34
You need to update resources in your PC3000 flash. But also you may need later version, I am not sure where XOR is stored - If you have latest version of software, and you downloaded resources, it should be there.
Also, some XOR ID will change over alternate software versions as far as I am aware
Posted: 21.12.17, 17:36
by Amarbir[CDR-Labs]
Hi ,
You Do You Have Controller : SM3257LT Q And Memory Chip ID : 0x2C846454 If yes register in Global Solution Center Then download this solution and apply it and check results .You should check if this XOR actually gives you good result manually if you like i am not in my system otherwise i could have told you
Posted: 21.12.17, 19:35
by Jaime
Thanks Amarbir,
I tried the solutions of the web global solution center, but it doesn't work.
How can I to try a new solution?
Posted: 22.12.17, 02:54
Jaime wrote:Source of the post Hello
Thanks Amarbir,
Hi ,
Controller + memory id were same ?
Posted: 22.12.17, 08:11
by Roman_TS
Hello Jaime. Make sure that you have the latest software version - PC-3000 Flash 7.1.1.4106. With latest update it become possible to update your resources and get the latest XOR in your database. If you have any problems with your case - please contact with our TS department:
Posted: 22.12.17, 17:40
by Jaime
The controler is en3257lt q ab
the memory $2CA4E554 - A9000000 MT29FxxG08CxCCB [SDR} PAGE 18272 BYTES (32 SECTORS) BLOCK SIZE 16384 SECTORES (512 PAGES)
Two part
The size of memory 64gb
Posted: 25.12.17, 08:41
by Roman_TS
Please contact our TS department, we will guide you.
Posted: 25.12.17, 16:00
Hi Jaime ,
Roman And Filipp Both Can Take a Look At Your Case If You Have Active TS Support License .Secondly The Link you gave is a total different solution its Based on The " Memory chip ID : 0x2C846454 " Which is different from your case .Can You Tell Me No of Flash Chips ,You Can Also Do XOR analysis - >
http://blog.acelab.eu.com/how-to-se ... terns.html
