help to recover data from sd card 512gb
Posted: 05.07.24, 16:40
by deyaa2012
Help in recover Lexar 512 as seen not detected over any reader or over pc3000 flash sd card adapter
WhatsApp Image 2024-07-05 at 17.35.56_282df8ee.jpg (12.78 KiB) Viewed 4209 times
Re: help to recover data from sd card 512gb
Posted: 05.07.24, 20:24
by Roman_TS
Hello. You need to remove the plastic cover. Most likely it's based on two BGA-132 + SM2704
Posted: 05.07.24, 21:48
by deyaa2012
It’s like that like there is sealed or protective no chip appeared
Posted: 06.07.24, 17:34
by deyaa2012
In such case any solution to remove protective cover or in this case using spider board ?
Posted: 08.07.24, 08:03
by deyaa2012
Can you guide me in such case what we will do ?
Posted: 09.07.24, 10:02
by Roman_TS
You should grind the bottom side of the monolith and try to find the target layout.
