Could not find ECC even after join by bytes.
Hemendra
Postby Hemendra » 04.03.21, 10:00
I have one chip Chip No : MT29F32G08TAA and it has one part but 2 chips in it.
So as suggested in some of posts I have tried to change the order and do join by bytes in order to find ECC but still no result is showing up.
Data map is showing quite good to expect result.
As I have attached image showing the info of chip along with page transformation details.
Controller : AU6983U
Thanks.
ECC not found with dual chip and single part
A21-174 ECC not found dual chip single part.png (66.31 KiB) Viewed 5903 times
Re: Could not find ECC even after join by bytes.
Postby Roman_TS » 04.03.21, 10:06
It doesn't make sense to ask your data recovery questions here :) Please use ticket system, and our engineers will guide you.
