Samsung 960 EVO 256GB
Posted: 12.06.18, 21:23
by MasterT
SSD is detected like this:
device manager.png (2.63 KiB) Viewed 13705 times
SSD Properties in Device Manager:
ssd properties.png (11.85 KiB) Viewed 13705 times
In Windows Disk Management it looks like this:
disk management.png (8.11 KiB) Viewed 13705 times
If i try to access it i get the following error:
error message.png (3.44 KiB) Viewed 13705 times
So in order to recover data i tried to start new task in Data Extractor but surprise, SSD is not detected:
task creation.png (10.01 KiB) Viewed 13705 times
Any hint on how to proceed?
Thank you very much.
Re: Samsung 860 EVO 256GB
Posted: 13.06.18, 09:57
by northwind
When you connect the drive to SATA0 in PC3K how does it behave?
Posted: 13.06.18, 11:14
by MasterT
Cannot connect to SATA0 because Samsung 960 EVO has PCI-express interface. And it can't be plugged in M.2 to SATA interface.
Posted: 13.06.18, 14:30
by Roman_TS
860 EVO - is a SATA based SSD. 960 EVO - is a PCI-E drive. So, which is yours? :)
Re: Samsung 960 EVO 256GB
Posted: 13.06.18, 14:40
by MasterT
It is 960 EVO.
Posted: 14.06.18, 10:55
by Roman_TS
PCI-E based drives are not supported by PC-3000 SSD for now. But we are working under solution which will be present in 2019.
