Tech=mode in C300 Micron Real SSD 128GB 2,5"
Posted: 18.04.16, 10:34
by Marek
I have case with SSD that when i turn it on in PC3000, state is RDY... When i want turn on utillity - SSD is change to BSY... And that is...
Not recognized ID, Capacity, etc...
Re: Tech=mode in C300 Micron Real SSD 128GB 2,5"
Posted: 25.04.16, 15:08
by Roman_TS
Hello! Looks like this drive has serious problem with FW - when you trying to send any command on it it goes in BSY. Will try to find what we can do.
P.S. This drive does not required hardware shorting for switching in SAFE.
Posted: 28.09.16, 16:13
by goooz
hello
are there any News with bsy Problem?
I have 88SS9190 Controller with same prob.
Posted: 29.09.16, 08:52
by Roman_TS
BSY problem is popular in Marvell based SSD. First of all, if you want to recover data from such drive, it should be supported by PC-3000 and your drive (exactly your model!). Also, in case if VanGogh (family of Marvell controllers) stay in BSY, need to wait for 1-2 hours. Sometimes drives goes in Ready after several minutes or hours - it's typical feature of those SSD. Something become corrupted inside drive Firmware, and it goes in loop loading. After some time it should finished all initialization processes and goes in READY. But usually it's useless because we still need technomode for data recovery, and if drive is not in the support list, we can't do anything.
Posted: 03.10.16, 14:17
by Marek
I see :)
Thank You so much :)
Best Regards :)
Posted: 09.10.16, 14:34
Roman_TS wrote:Source of the post BSY problem is popular in Marvell based SSD. First of all, if you want to recover data from such drive, it should be supported by PC-3000 and your drive (exactly your model!). Also, in case if VanGogh (family of Marvell controllers) stay in BSY, need to wait for 1-2 hours. Sometimes drives goes in Ready after several minutes or hours - it's typical feature of those SSD. Something become corrupted inside drive Firmware, and it goes in loop loading. After some time it should finished all initialization processes and goes in READY. But usually it's useless because we still need technomode for data recovery, and if drive is not in the support list, we can't do anything.
Hello ,
When Can we see new update its been virtually so many months without it ,The UV300 Phision S10 Controller Support Etc Etc .BTW It Was Me Along With Vijayan Just 2 To 3 Days Before Were You Came And Assisted Us For a Remote Recovery :D .Still Learning But i Will Definitely Bo Good in This Few Months Later
